Moisture
cirujanoramirez
Updated at 2021-08-11 12:38:30 UTC
View: 8223   Answer: 1
Francesco G
Updated at 2021-08-08 17:24:19 UTC
View: 6876   Answer: 1
One zone not working
S Yarrish
Updated at 2021-08-06 00:50:19 UTC
View: 8395   Answer: 1
Weather Provider Error
Jacques
Updated at 2021-08-03 22:26:44 UTC
View: 8977   Answer: 2
Brian Brun
Updated at 2021-08-03 02:40:17 UTC
View: 7250   Answer: 1
Just setup metro pixie.
mprtjd
Updated at 2021-08-01 18:26:34 UTC
View: 7369   Answer: 2
Data out of the API
Jens Wymeersch
Updated at 2021-08-01 13:24:46 UTC
Dear Netro,
View: 7530   Answer: 2
Paco Gómez
Updated at 2021-08-01 05:26:03 UTC
Un saludo
View: 6688   Answer: 1
no wifi connection mqtt blocked
Updated at 2021-07-30 18:16:05 UTC
i received Netro programmer
no connection
i have a fritbox 7560
the server status message says
mqtt blocked port 1883
View: 9742   Answer: 1
Moisture all day
Shai Amiel
Updated at 2021-07-29 03:30:05 UTC
With smart schedule on, sometimes I see "moisture all day" sign to some zones.
What does it mean and what do the application do?
Shai
View: 8526   Answer: 1
Netro and Home Assistant
Jens Wymeersch
Updated at 2021-07-28 18:18:16 UTC
View: 16090   Comment: 7
David Farries
Updated at 2021-07-28 02:11:18 UTC
View: 7578   Answer: 1
Updated at 2021-07-26 16:02:28 UTC
View: 9140   Answer: 2
Rain sensor
Updated at 2021-07-26 12:13:34 UTC
View: 9138   Answer: 1
Installing New Netro-6
Debby Plenert
Updated at 2021-07-25 14:37:04 UTC
I removed an older controller and replicated the wiring when installing the new Netro.  Everything appears to be correct?  However, when watering is activated, the valves will fill up and vibrate or what not with water rushing internally.  But the sprinkler heads don’t pop up and no water comes out.  Any help here would be greatly appreciated.  Thanks!
View: 8992   Answer: 1
Eric
Updated at 2021-07-25 05:56:52 UTC
View: 6707   Answer: 1
Strange Whisperer Acrtivity
Updated at 2021-07-24 17:00:16 UTC
View: 11898   Answer: 5
Keep Online
bechard
Updated at 2021-07-24 11:09:25 UTC
View: 7882   Answer: 0
Connect to a network
James Yates
Updated at 2021-07-22 21:08:14 UTC
View: 6595   Answer: 1
Two electro valves activated at same time
Francesc Rodríguez
Updated at 2021-07-21 20:07:01 UTC
Why is not possible two valves operating at the same time if the pump can be operate correctly?
View: 9144   Answer: 1
