Rocky Hill
Updated at 2021-07-05 12:35:21 UTC
  • Tomatoes;
View: 14066   Answer: 2
Another use netro sprite
Alejandro
Updated at 2021-07-05 12:17:57 UTC
Good afternoon
Greetings
View: 8100   Answer: 1
tester mon installation
raynaud patricia
Updated at 2021-07-04 16:45:15 UTC
Bonjour,
merci
View: 6436   Answer: 1
Set up additional device
Mark Vandeberghe
Updated at 2021-06-29 15:42:49 UTC
View: 8592   Answer: 1
Anyone actually Beta Testing
Updated at 2021-06-29 14:10:59 UTC
View: 7636   Answer: 2
Installation of my Device
JD Dakak
Updated at 2021-06-28 18:15:34 UTC
I need help with that.
View: 8711   Answer: 2
Shawn C
Updated at 2021-06-27 16:26:16 UTC
View: 7120   Answer: 2
Why
Updated at 2021-06-26 14:59:00 UTC
View: 8888   Answer: 1
Zero Readings
Billy Wood
Updated at 2021-06-26 00:28:05 UTC
View: 8395   Answer: 1
Mike Willet
Updated at 2021-06-24 20:47:47 UTC
3 for backyard
3 for front yard
1 for drip irrigation in back
View: 8059   Answer: 1
Can’t Delete Whisper Sensor
Mike Willet
Updated at 2021-06-24 20:40:43 UTC
View: 6701   Answer: 1
Sensor not reading moisture
8
Updated at 2021-06-24 19:37:55 UTC
I have three whisper sensors,  all of them  but one is reporting moisture levels.  Temperature and sunlight are correct, but moisture is 0%.. I have reset the self learning, Did a hard reboot, and  Reattached the sensor to a different wireless network.  What else can be done?
View: 8028   Answer: 1
Reset whisper sensor
Yuriy Andamasov
Updated at 2021-06-24 18:06:20 UTC
Like hard reset
Not like that
View: 8502   Answer: 1
Still irigates on rain days
Anyhony Harwood
Updated at 2021-06-24 11:30:50 UTC
View: 8054   Answer: 1
Ken Laberteaux
Updated at 2021-06-22 04:16:23 UTC
View: 8647   Answer: 2
Richtiger niederschlag
Gregor Schuller
Updated at 2021-06-21 09:41:39 UTC
Hallo,
Zurzeit ist nur 1 mm möglich
View: 6982   Answer: 1
Programs that ignore sensors?
Jacques
Updated at 2021-06-20 19:10:17 UTC
View: 8413   Answer: 1
BOB COOPER
Updated at 2021-06-20 16:40:50 UTC
View: 11449   Answer: 1
Smart watering
Scott Schoenfeld
Updated at 2021-06-19 18:25:03 UTC
View: 7026   Answer: 2
Google home
Sasha Obradovic
Updated at 2021-06-18 13:56:27 UTC
View: 7341   Answer: 2
