Google home
Sasha Obradovic
Updated at 2021-06-18 13:56:27 UTC
View: 7632   Answer: 2
aceking
Updated at 2021-06-18 12:41:57 UTC
View: 6929   Answer: 2
Junk box pixie
Ray Williams
Updated at 2021-06-17 22:30:16 UTC
So Dissatisfied
View: 12015   Comment: 1
How to turn off Smart control
Riccardo Secco
Updated at 2021-06-17 19:47:41 UTC
View: 7102   Answer: 1
Smart zone predictions?
Sid Smith
Updated at 2021-06-17 12:12:33 UTC
View: 7321   Answer: 1
Network error
Al Piscopo
Updated at 2021-06-17 10:27:03 UTC
View: 6746   Answer: 1
System stuck on watering
Haris Eliades
Updated at 2021-06-17 05:07:11 UTC
View: 7309   Answer: 2
Jen Wells
Updated at 2021-06-17 00:36:39 UTC
View: 7384   Answer: 1
Updated at 2021-06-16 14:03:50 UTC
View: 7718   Answer: 1
Watering adjustment settings
Lyndon Whyatt
Updated at 2021-06-15 16:55:38 UTC
View: 7588   Answer: 2
klzig
Updated at 2021-06-15 14:16:19 UTC
View: 8264   Answer: 1
Backup
klzig
Updated at 2021-06-15 14:09:28 UTC
Best I can tell from the cursory technical specs is that for the Sprite the backup for a custom (not smart) watering schedule is in the cloud and for the Spark the backup is stored on-device in nonvolatile memory.  Is this correct?
View: 8545   Answer: 1
whisperer + smartzone
Updated at 2021-06-14 20:59:45 UTC
View: 9133   Answer: 1
Rebekah H
Updated at 2021-06-13 19:48:23 UTC
Any ideas?
Rebekah
View: 7559   Answer: 2
Whisperer Bad Readings
Billy Wood
Updated at 2021-06-13 19:42:18 UTC
View: 8685   Answer: 1
Connection issue
bridgethr
Updated at 2021-06-13 18:17:52 UTC
View: 7400   Answer: 2
Installation of sprite
Mark Killeen
Updated at 2021-06-12 21:53:35 UTC
I have all connected and seems fine but when testing turning on each station I get a "pending" but no sction!
Each zone then said"loading"  for 5 minutes each then nothing. Please offer any help!
View: 9322   Answer: 2
Text overlap in App
Kevin Westling
Updated at 2021-06-12 14:46:02 UTC
View: 7314   Answer: 1
Confused....to sensor or not to sensor?
Kevin Westling
Updated at 2021-06-12 14:37:12 UTC
I'm only using a sprinkler system to water St. Augustine grass on a .2 acres in South Florida. The entire area is flat and has the same soil make-up (loam). Direct sunlight shines mostly all day on every area other than a small 10'x40' strip on the west side of the house that is shaded part of the day. I have no trees and no plants. I have a Sprite controller and 1 whisperer sensor which is connected to the 3 zones that get the most sunlight. The learned % is at 55%
I don't see any benefit in using the whisperer. Thoughts?
View: 8849   Answer: 1
Change sensor zone?
Jeff W
Updated at 2021-06-12 14:23:07 UTC
View: 7094   Answer: 1
