Whisperer won't blink white during setup
Kevin Westling
Updated at 2021-06-12 03:01:46 UTC
Prior to installing a whisperer to my system, I set it up outside in direct sunlight for 5 days. When I try to add it to my Sprite, the light only blinks red once. I've tried multiple times to press the power button 6 times and it's still just flashing red just once. What am I doing wrong?
View: 9388   Answer: 1
Looking for Beta testers
Updated at 2021-06-11 06:11:28 UTC
Dear all Netro customers,
The long waited new version (3.0.0) of the Netro app is on the horizon. The major improvements of this version are
1. faster in loading data
2. new manual run interface
3. new home view design
4. more languages supported
We sincerely invite you to join the Beta testing program. Please email to support@netrohome.com or leave a message below if you would like to try the new app. Any feedback would be greatly appreciated !
Netro App Team
View: 32150   Comment: 60
Marigolds
Updated at 2021-06-10 23:51:43 UTC
What is eating my marigolds
View: 7355   Answer: 0
Skipping watering
Sid Smith
Updated at 2021-06-10 21:05:17 UTC
View: 8803   Answer: 1
Skipping watering
Sid Smith
Updated at 2021-06-10 21:04:56 UTC
View: 8593   Answer: 0
Updated at 2021-06-10 05:30:31 UTC
View: 7472   Answer: 1
Choice of irrigation hardware
Lyndon Whyatt
Updated at 2021-06-09 21:01:28 UTC
Hi I have ordered a Netro spark controller and three sensors. My next step is choosing 12VAC solenoids, a drip irrigation system for beds and pots and a misting system for my propagation bench.
I am new to this and would appreciate a pointer to recommended setups and suppliers.
Do I locate valves near to the Spark and run underground hoses to my beds or am I better off running cables to valves next to the beds? What are the pros and cons?
View: 9417   Answer: 1
Spark not watering lawn
Updated at 2021-06-09 14:26:58 UTC
View: 7833   Answer: 1
Network Error With Code: 3404
Ian Meyer
Updated at 2021-06-08 16:16:25 UTC
View: 7551   Answer: 1
Low pressure on pixie
Martin Le Ménach
Updated at 2021-06-08 07:20:16 UTC
View: 8557   Answer: 1
Gianluca De Virgilio
Updated at 2021-06-07 16:13:28 UTC
Good afternoon,
Gianluca
View: 8885   Answer: 1
Whisperer in the UK
Lyndon Whyatt
Updated at 2021-06-07 10:59:12 UTC
View: 9531   Answer: 1
Pause a location\device
Jon Storch
Updated at 2021-06-06 23:08:20 UTC
-Jon Storch
View: 7471   Answer: 1
beta tester
Updated at 2021-06-06 07:50:32 UTC
View: 7794   Answer: 1
Schedule stopped working
Updated at 2021-06-04 20:37:36 UTC
View: 7759   Answer: 1
Best time for irrigating
Updated at 2021-06-04 19:44:57 UTC
Late in the night, 21, 22.h
Thx
View: 9184   Answer: 2
Manual Watering
Kevin Westling
Updated at 2021-06-04 00:42:16 UTC
View: 7369   Answer: 1
Weather
Updated at 2021-06-03 14:47:01 UTC
Good afternoon,
View: 9041   Answer: 1
Moisture level correction
Updated at 2021-06-02 21:51:35 UTC
View: 9101   Answer: 3
sal.jamil@me.com
Updated at 2021-06-02 12:11:24 UTC
View: 7079   Answer: 1
