Jason
Updated at 2021-04-20 21:49:32 UTC
View: 6469   Answer: 1
Mitch Green
Updated at 2021-04-20 00:44:59 UTC
View: 7604   Answer: 1
Michael Sheahan
Updated at 2021-04-19 21:19:54 UTC
View: 8048   Answer: 1
Email address
Troy pascoe st
Updated at 2021-04-19 11:01:30 UTC
View: 6683   Answer: 1
dougbrandes
Updated at 2021-04-19 10:06:30 UTC
View: 6732   Answer: 1
Whisperer sensor soil type
Aki Lan
Updated at 2021-04-17 13:47:25 UTC
Is whisperer sensor able to know your soil type due to drain capacity?
View: 8152   Answer: 1
Multiple Pixies?
J Forrest
Updated at 2021-04-17 03:33:18 UTC
View: 6737   Answer: 1
How to delete a device
Carles
Updated at 2021-04-16 12:33:31 UTC
View: 7079   Answer: 1
Time zone not supported
Havre de Grace
Updated at 2021-04-15 08:11:30 UTC
I keep getting this error when I try to put my address in Jersey, Channel Islands.
View: 6454   Answer: 1
Manual start on demand
Krzysztof Wiater
Updated at 2021-04-14 03:34:58 UTC
I just got unit garden hose pixie unit. I am looking for a manual watering on demand button. I want to be able to turn it on and off an needed. Right now i see I have to wait 1 hr or so to turn it on. Am I missing something here? Please help. Thanks in advance.
View: 8369   Answer: 1
How to Set Schedule?
tonycurry
Updated at 2021-04-14 02:13:12 UTC
View: 6845   Answer: 1
Fabio Pellizzoni
Updated at 2021-04-13 20:10:43 UTC
Do you have any idea why ?
View: 6875   Answer: 1
Tony Pellegrino
Updated at 2021-04-13 19:14:36 UTC
View: 8151   Answer: 1
Imran Ali
Updated at 2021-04-12 22:54:05 UTC
Imran Ali
View: 7099   Answer: 1
Timezone not supported
Shai Amiel
Updated at 2021-04-11 19:33:24 UTC
why do i get this error? I am trying to install in israel
View: 8253   Answer: 1
Scott Gustafson
Updated at 2021-04-10 16:04:18 UTC
Scott
View: 7432   Answer: 1
Disable a zone
fernando colon
Updated at 2021-04-10 14:15:21 UTC
View: 11340   Answer: 1
Moisture Level
Des Mullin
Updated at 2021-04-09 23:48:09 UTC
View: 7270   Answer: 1
Adding multiple sensors to a Pixie
phatd
Updated at 2021-04-09 18:13:11 UTC
I have a mister setup with multiple Herb racks and raised garden beds. I just got a Pixie and a few Whispers. My hope was using one Pixie and monitoring each bed with a whisper. Is this possible? Can I create multiple zones? Is this something going forward that might be possible? I don't want to set them up as standalones.
View: 8145   Answer: 1
Abel Vargas
Updated at 2021-04-09 00:49:42 UTC
View: 11436   Answer: 1
