David Farries
Updated at 2021-04-07 02:16:14 UTC
View: 6908   Answer: 1
jjmengibar
Updated at 2021-04-05 18:19:11 UTC
View: 8840   Answer: 1
jjmengibar
Updated at 2021-04-05 18:16:46 UTC
How can I reset any zone
View: 7384   Answer: 1
Can’t start Netro
Joe Horner
Updated at 2021-04-05 14:47:49 UTC
I have a good WiFi signal.
View: 6581   Answer: 1
Does the Pixle have to be installed with the water coming into it on the "Hose Faucet Connection" side?
Austin Franklin
Updated at 2021-04-03 19:04:13 UTC
Basically, is the Pixie water control valve one way, or can it shut off/turn on with pressure from either side?  In order to install it so the button faces up, I need to install it so the water comes in what is labeled as the "Outlet" side.  I don't know if it's labeled "Outlet" because it is a male connection, or because it cares about the direction of the water.  Otherwise, I will need to buy a male/male and female/female adapter, flip it "upside down" and use it with the button facing down.
View: 8032   Answer: 1
Many inexplicable Manual runs
Panos Charalambopoulos
Updated at 2021-04-03 11:37:15 UTC
Hello everyone ,
View: 8246   Answer: 1
Instant watering
hermanins@gmail.com
Updated at 2021-04-03 00:01:28 UTC
View: 6593   Answer: 1
Light flashing
lightnin
Updated at 2021-04-01 19:11:23 UTC
Why is my light flashing on my Netro?
View: 8105   Answer: 2
Firmware update
Francesco Angelone
Updated at 2021-04-01 13:33:34 UTC
my firmware version is the 1.1.1
Please, can I have the last firmware vesion and the instructions for update my controller.
The serial number is E4956E4B6B05
View: 8492   Answer: 1
What do the icons mean?
Jim Stichbury
Updated at 2021-03-31 06:55:06 UTC
View: 6811   Answer: 1
Server offline
Mirko Paganelli
Updated at 2021-03-30 16:15:01 UTC
View: 7112   Answer: 1
Updated at 2021-03-29 08:57:05 UTC
I have checked in the smart schedule that tomorrow is programmed to run zones that should be skipped.
I have set up the whisperer to skip run if moisture is above 40%. Current moisture is:
  • Zone 2 - 92%
  • Zone 5 - 70%
View: 7548   Answer: 2
Kevin Westling
Updated at 2021-03-28 06:40:48 UTC
View: 6964   Answer: 1
Wild Swings In Moisture %
Mike Biondo
Updated at 2021-03-27 22:08:54 UTC
I am seeing 20%+ increases in soil moisture when there is no rain and I am not watering and also 20%+ reductions in moisture directly after watering which seems counterintuitive. Is this normal? Can anyone explain what is going on to me? Thank you!
Mike
View: 8609   Answer: 1
Ideal Soil Moisture
Mike Biondo
Updated at 2021-03-26 01:51:09 UTC
What is an ideal soil moisture level? My new Netro Whisper is measuring 83% down from 88% 3 hours ago. Is this too moist? It is average raised bed plant soil. I have googled and found some sites saying no more than 45% and some sites say no less than 70% so I am very confused!
View: 11565   Answer: 1
sprite subscription
Alejandro
Updated at 2021-03-24 09:06:34 UTC
I am interested in buying the netro sprite but there is something I dont understand about the annual subscription (I do not understand English very well).
What stops working in the netro sprite if I don't have a renewed subscription?
View: 8548   Answer: 1
No power to controller
Barbara Williams
Updated at 2021-03-23 16:10:05 UTC
Our controller has been working fine, and we had to replace some solenoids that were faulty. The controller is plugged into a verified live socket but no lights turn on. I can't hook up wifi, and it appears to be dead.
View: 6876   Answer: 1
When will be Netro Smart available in Europe?
Raúl Vázquez-Noguerol Méndez
Updated at 2021-03-20 20:38:05 UTC
I’d like to know if Netro Spark will be available in Europe.
View: 6672   Answer: 1
Standalone whisper asking me to water every day
MartynCarr1972
Updated at 2021-03-18 08:43:41 UTC
Hi have a standalone sensor in  a pot indoors. For the last 4 days since I have had it running its asked me to water every day. Which I have. I would like to know what the parameters for my plant are for it requesting water.
Also it shows 2% battery in the app in the day and 0% at night. The web app shows 15% all the time it seems.
Anyone have similar issues?
View: 8611   Answer: 1
What does the app show for whisperer?
Growbro
Updated at 2021-03-17 20:54:48 UTC
I am trying to figure out what the graph shows for the week. It seems like the app shows the average light for the day. Moisture present at midnight each day. And average temperature each day. Is this correct? Or is it maximum temperature for the day?
It would be nice if I could have the graph could show more than just one reading per day. It would also be nice if you could go back and see the more detailed chart for a full day after it has passed. As it is now I can only see the one data point for days that are past.
Finally for the individual days it is a bit annoying switching between am and pm. I wish there was just a graph for each day that looked like the graph for the week/month except that there was a data point for every hour. Definitely more annoying and less useful to have am and pm separate and not be able to see the changes like you can with the graph.
View: 6798   Answer: 1
