Technical question
Enrique Campos Sanchez
Updated at 2021-01-14 20:36:25 UTC
Hi team.
I would like to know what is the maximun wire longitude that support by zone the Netro Driver using 24 VAC power supply.
Thank´s.
View: 8410   Answer: 1
MAC address
John Conley
Updated at 2021-01-07 15:26:26 UTC
View: 6829   Answer: 1
Darren Cassar
Updated at 2021-01-05 11:03:18 UTC
Darren
View: 6892   Answer: 1
Moisture and light range
Don Lewandowski
Updated at 2020-12-31 21:46:19 UTC
View: 11362   Answer: 1
Metro France cloud down?
Julian Hansen
Updated at 2020-12-29 01:07:40 UTC
View: 7459   Answer: 1
Roman Stanek
Updated at 2020-12-27 18:34:40 UTC
View: 6677   Answer: 1
Pixie Valve Issue
Alec Simonson
Updated at 2020-12-15 05:48:10 UTC
Alec
View: 7624   Answer: 2
Sensor Temperature Reporting
Nasser Ahmed
Updated at 2020-12-14 02:12:42 UTC
One of my sensors is reporting strange temperature numbers. Any ideas on how to fix this. I tried a reboot and a reset (remove and add again).
View: 6966   Answer: 1
Automatic switch to 12 hour reporting for sensors
Julian Hansen
Updated at 2020-12-10 12:30:21 UTC
Hi I have 6 senors that have all worked perfectly for 3 months unattended. A month ago I noticed 1of them only had 5% charge so I switched it to 12 hour reporting and it is now on 38%. Today another sensor has gone to 0% charge and stopped reporting. It would be great if you could be set it automatically switch at say 30% charge. It will be 3 months before I am back to the house so I hope the sensor can recover. Thanks for a fantastic product.
View: 7460   Answer: 1
Moisture uncorrect
Andrea Pieri
Updated at 2020-12-08 05:43:25 UTC
View: 11232   Answer: 1
Battery dead
Arthur
Updated at 2020-12-07 22:00:27 UTC
View: 7168   Answer: 1
How to make Netro sensor repair
Bowie Xu
Updated at 2020-12-06 21:04:42 UTC
My sensor doesn’t blink white led. When I presses the power button, it shows solid white for a while and then green color and red and goes off. The instructions make me confused. I tried to press the power button for 6 times. What does restart 3 times means? My sensor never goes to blinking white color.
View: 9058   Answer: 1
Master valve timing
joeac
Updated at 2020-12-04 05:38:31 UTC
Product: Sprite
Joe
View: 8402   Answer: 1
Haris Eliades
Updated at 2020-11-25 06:25:20 UTC
Haris
View: 7224   Answer: 3
Whisperer Battery
growerken
Updated at 2020-11-23 16:44:00 UTC
I have one whisperer,used in indoor garden.it looks like the solar is not enough for the charging.
Any idea I can fix it?
View: 9025   Answer: 1
Sensor and zone of control
Andrea Pieri
Updated at 2020-11-20 19:49:29 UTC
Dear support right now i am installing my new sensor connected with netro controller ( this is the first sensor) . I have 5 zone active but sensor is able to control just 3 zone is possibile to extend the sensor control  to a global of 5 zone for one sensor ? Thanks for your help .
View: 8624   Answer: 1
App stuck on Idle
Pam Manwaring
Updated at 2020-11-18 02:21:16 UTC
View: 6777   Answer: 1
Jens Wymeersch
Updated at 2020-11-17 13:25:17 UTC
Dear,
Thank you so much,
Jens
View: 8027   Answer: 2
Stan Balafas
Updated at 2020-11-16 17:52:28 UTC
Thank ypu
View: 6866   Answer: 1
Offline buy watered
Haris Eliades
Updated at 2020-11-09 06:22:11 UTC
View: 7065   Answer: 1
