Installation help
Francesco G
Updated at 2020-07-31 18:47:07 UTC
Greetings from Italy
this Monday I will receive my Netro Smart Irrigation controller and I have some concerns about the power supply.
On the YouTube video guide I saw there are 2 slots to put the power cables but I was only able to find a regular 24V power adapter with one single output.
Do I have to cut the power jack off and split the cables in order to put them in the controller?
thanks in advance for your help, can’t wait to become part of the Netro family!
this is the power adapter I ordered: Alimentatore 220 V – 24 V/1000mA https://www.amazon.it/dp/B00AWU8NUM/ref=cm_sw_r_cp_api_i_OBgjFbJ8Q41F1
this is the Netro device I ordered: Netro Sprinkler Smart Controller, WiFi, Meteo consapevoli, Accesso remoto, 12 Zone, w/o Adattatore di Alimentazione https://www.amazon.it/dp/B07DGT7ZK1/ref=cm_sw_r_cp_api_i_iCgjFbP0QZ4DH
View: 8644   Answer: 0
Centralina non chiude valvola
Stefano Sabelli
Updated at 2020-07-31 18:26:17 UTC
Buonasera a tutti,
Da questa mattina la centralina non mi chiude più la valvola della linea 1 dell’impianto... ho provato a fare reset ma niente continua con irrigazione!!
Sono riuscito a sospendere irrigazione reimpostando da capo la centralina ma il problema e sulla linea 1 che non a trova più anche quando metto programma irrigazione.
Grazie mille
View: 8822   Answer: 1
Water turned off
Ken Laberteaux
Updated at 2020-07-31 01:08:39 UTC
I had to turn off my water valve to my sprinkler system for a week (ending in a few days) and forgot to disable smart watering on my netro.  Netro thinks it did a complete watering last Saturday, and adjusted estimated soil moisture accordingly.  Netro isn't planning another watering for another 9-10 days.  However no watering last Saturday occurred.
How best should I handle this?  Is there a way to delete past watering, which will lower soil estimated moisture, triggering a sooner watering than currently scheduled?  Or should I just do a manual long watering as soon as I can?
View: 7737   Answer: 1
Arthur
Updated at 2020-07-30 22:20:53 UTC
Arthur
View: 7281   Answer: 1
Updated at 2020-07-28 05:32:10 UTC
I have an issue/conflict  with the watering adjustments for the sensors and the Smart Zone Sheduling
I have seen something weird.
  • I Have set up the Watering Adjustment for sensors the following I describe o be sure about the problem
  • Moisture to Skip watering 50%
  • Moisture to Add watering 30%
  • Duration 5 minutes (only) -- it is a check
  • The Smart Zones are st up the following
  • Smart Zone - enabled
  • Mode - regular
The watering run today only 5 minutes, when the smart  schedule  defined by the system was above that. As you can see, tomorrow watering says different time runs per zone, but it will run a maximum of 5 minutes. This means that the sensor configuration overrides the Smart Zone. And it should not.
As far as I understand the Watering adjustemt is to add EXTRA watering when needed based on the moisture level. Attached picture
Prior to this setup I had the Duration for Watering Adjustment for 15  and 10 minutes, and you can see in the past days runs, that always run for 15 -10 minutes depending the zone/sensor. - Attached picture
In previous weeks, it was working fine and adding extra watering when need it to keep the moisture levels.
Any idea?
I DID THE CHANGES PROPOSED BY NETRO  and it is not working
Take a look the screen shots
Zones 3,4,5 it is below the 30% trigger
View: 8100   Answer: 1
Skipped watering on calendar and the system still watered...
Daniel Schoonover
Updated at 2020-07-26 01:36:47 UTC
I noticed system was going to water this afternoon so I skied the watering on the calendar hours before.
When the time came the system still watered my yard?
Why?
And I could not find a single way to stop it.
View: 8674   Answer: 1
Rain Delay
R H
Updated at 2020-07-25 04:47:00 UTC
View: 7370   Answer: 1
Centralina offline
Stefano Sabelli
Updated at 2020-07-21 10:08:27 UTC
Buongiorno a tutti,
grazie mille
Saluti
Stefano
View: 7219   Answer: 1
ifttt or .ics support
Michael Landesman
Updated at 2020-07-20 19:01:42 UTC
View: 7345   Answer: 1
Whisperer reset WIFI does not work
ozieaev
Updated at 2020-07-19 14:38:29 UTC
Got 2 Whisperer sensors recently. They came up not new (see some scratches on them and signs of use). As a part of install had to reset WIFI settings in order to connect to my WIFI. Pressing power shows red led. Issue is - pressing power 6 times (should switch to WIFI setup mode), does not work either. Still RED light.
Does anyone knows how to fix this?
View: 8906   Answer: 4
Addiel Isaac Moldes
Updated at 2020-07-19 11:43:54 UTC
View: 10653   Comment: 2
I'm not understanding how "estimated frequency and duration" works...
Izio Sem
Updated at 2020-07-18 07:24:18 UTC
Ciao.
Just installed Netro Sprite.
I enjoyed to set up the zones with advanced Smart watering, but I'm not confident with what is reported in "estimated frequency and duration". The frequency showed in the setting page seems too long (e.g. every 6 days)... but, if I see what is scheduled in the calendar it seems much closer to my expectation (e.g. every 2 days).   How daoes it work??
Maurizio
View: 7908   Answer: 1
Netro Sprite dead after 27 months (3 months post-warranty)
Doug Burkott
Updated at 2020-07-17 11:26:34 UTC
Has anyone had an issue with their Sprite being inoperable shortly after the warranty ended?  I tested the power prongs with a voltmeter and the controller is getting electricity, but no lights are on.   It's 105 deg in Austin and no rain in sight.  I'm going out of town for 5 days, so I'm in trouble.  I'm going to have to go to Home Depot to get something off the shelf installed today before my trip.
Anyone with the same problem?  Has anyone been successful with a claim outside of the warranty period?
Update:  The Sprite went offline at the same time the LED light stopped working.  The watering schedule resumed two days later and the LED was still off.  Meaning - Sprite works fine, LED doesn't work.  Netro told me to send the unit in over the winter and they will repair the LED.  Awesome - thanks Netro!
All the best,
-Doug
View: 9505   Answer: 2
Does Netro whisperer underestimate moisture?
Rick Agrawal
Updated at 2020-07-16 19:12:17 UTC
I added a whisperer to one of our zones. Recently the moisture content was between 25-30%. We are having a hot summer with many days with 110 degrees. I believed it and watered for good 15-20 minutes. It turned out despite all those water the soil moisture went up to 45-50%. I went and checked again, the soil looks pretty good and appeared moist.
Just curious if the whisperer tends to underestimate moisture?
View: 7297   Answer: 1
Watering Frequency
Andrei Stancovici
Updated at 2020-07-16 05:36:44 UTC
Hello.
I installed my netro yesterday and now after watering all zones it shows me that the next watering will be in 5 days. It seems to be to far away in the future since it's 35 degrees celsius and sunny all day
View: 7106   Answer: 1
Smart watering issue?
Ananth
Updated at 2020-07-15 13:14:40 UTC
View: 7918   Answer: 1
Whisperer night light
Arthur
Updated at 2020-07-15 05:45:42 UTC
I have 2 whisperers. Both have the nightlight enabled to auto but only one of them turns it on at night the other never does. Any advice?
View: 8816   Answer: 2
user manual in spanish
Alejandro
Updated at 2020-07-14 10:00:20 UTC
View: 7637   Answer: 1
Does Pixie timer have an integrated water back flow?
Sierra Kiner
Updated at 2020-07-13 17:27:01 UTC
Is water backflow integrated into the Pixie timer or does installation require a separate one?
View: 9303   Answer: 1
Offline sratusc
Andrea Del Ben
Updated at 2020-07-12 19:31:12 UTC
View: 8842   Answer: 1
