Maegan Nelson
Updated at 2020-06-10 08:59:42 UTC
View: 7209   Answer: 1
Andrey
Updated at 2020-06-10 04:38:59 UTC
View: 7141   Answer: 1
Rain Delay
R H
Updated at 2020-06-10 03:03:28 UTC
Why or how does the rain delay option work?
Mine is set up with the minimum rain but the program still goes off no matter what.
My B-hyve sends me a “rain delay” message.
View: 9925   Answer: 1
Jason Wire
Updated at 2020-06-08 21:50:29 UTC
View: 7194   Answer: 1
JDWalburg
Updated at 2020-06-08 15:26:52 UTC
View: 7027   Answer: 1
Thanks for IFTTT
Joe Ryan
Updated at 2020-06-07 22:38:39 UTC
View: 7493   Answer: 1
Simone Nolletti
Updated at 2020-06-07 19:32:59 UTC
View: 9694   Answer: 1
Netro is live on IFTTT
Updated at 2020-06-07 09:01:11 UTC
View: 13070   Comment: 4
A way to dial it down
esassone
Updated at 2020-06-07 01:51:41 UTC
View: 6972   Answer: 1
OPCIONES
Ernesto
Updated at 2020-06-06 16:01:17 UTC
View: 8259   Answer: 1
Upgrading from 6 to 12 zones
Carlos Oliveira
Updated at 2020-06-05 21:10:19 UTC
View: 9758   Answer: 1
Timer
Gary Niederpruem
Updated at 2020-06-04 12:08:43 UTC
View: 7036   Answer: 1
Notes section per zone
Simon Clark
Updated at 2020-06-04 07:13:33 UTC
View: 7682   Answer: 1
Metrosideros (Myrtaceae)
Alessandro Raffi
Updated at 2020-06-03 21:09:16 UTC
Thanks a lot,
Ale
View: 12018   Answer: 1
Watering metrics question
Egan
Updated at 2020-06-03 16:09:22 UTC
Todd in Texas
View: 7494   Answer: 2
Netro Sprite non apre le valvole
Simone Nolletti
Updated at 2020-06-03 09:40:36 UTC
valvole hunter 24vac, netro non apre le valvole.
i collegamenti sono stati eseguiti come da istruzioni.
Quale può essere il problema?
Alimentatore 24v 1000ma e’ corretto?
View: 10080   Answer: 1
Moisture to Skip Watering
Updated at 2020-06-02 23:59:08 UTC
View: 7659   Answer: 1
Smart things?
S D
Updated at 2020-06-01 23:14:05 UTC
View: 6668   Answer: 0
Missing Whisperer
guags99
Updated at 2020-05-29 18:11:36 UTC
This season when I put my whisperer back out to monitor my garden bed I looked on the app and no longer saw that device. So I went through the process to re-add it to my network and my Netro account and I get an error message stating that that serial number is already registered.  Anyone have any thoughts on how I can de-register and re-register this device?  Thanks
View: 9846   Answer: 1
Jesse For
Updated at 2020-05-29 08:33:36 UTC
View: 7098   Answer: 1
