What about your API ?
Updated at 2020-08-29 17:19:23 UTC
Christophe
View: 8121   Answer: 2
water connection of Pixie
graziani
Updated at 2020-08-27 08:29:42 UTC
can you please confirm sizes of water connection, I don't find on the website
View: 8524   Answer: 1
Add manager
Fabio Pellizzoni
Updated at 2020-08-27 08:26:50 UTC
View: 7069   Answer: 1
Battery not charging
Petar Nedyalkov
Updated at 2020-08-21 18:24:41 UTC
My solar powered controller doesn’t charge its battery - not sure if it’s a battery problem - the controller is under direct sunlight for at least 6 hours every day.
I’ve set it to water for 1 hour every day so it’s a simple On/Off once a day.
Have other people had this issue?
View: 9130   Answer: 2
Arthur
Updated at 2020-08-20 03:58:15 UTC
View: 6979   Answer: 1
Unable to reset into Host mode to change WiFi setting
dabo
Updated at 2020-08-16 17:29:54 UTC
I have a 6 zone Netro sprite and need to update my wifi settings. No matter what I do I'm unable to get the Netro to enter host mode. I've tried hitting the RST button numerous times before or after manual reboots (even waiting the full 3+ minutes after re-plugging the device in). I even tried a full manual reset by holding the RST button for 10 seconds and the device still doesn't reset. I'm starting to doubt whether the reset button on my device works.
Has any one had any similar problems or pointers for just getting the Netro to join a new WiFi network? I'd rather not do a full reset and lose my zone settings, but at this point I've even tried that and can't get that working.
View: 8718   Answer: 2
What does this mean?
Bowie Xu
Updated at 2020-08-16 16:58:18 UTC
Thanks in advance.
Bowie
View: 7567   Answer: 1
No funciona
Fre Camp
Updated at 2020-08-13 07:40:48 UTC
En la APP todo parece ir bien, pero no riega.
View: 8597   Answer: 2
Battery not holding charge
Steve Walczak
Updated at 2020-08-12 17:49:20 UTC
View: 8491   Answer: 2
Lost connection on holidays
lekter
Updated at 2020-08-12 08:45:08 UTC
I'm on vacation and my internet connection has been cut off. I had planned before on netro waterings for the week. Is that without an internet connection in my house, the waterings programmed before will still be done?
Arnaud
View: 7425   Answer: 2
Network error
Fre Camp
Updated at 2020-08-11 22:36:39 UTC
No funcionan los aspersores
View: 7174   Answer: 2
Sensor umidity
Andrea
Updated at 2020-08-09 16:14:57 UTC
I have two sensors installed for a few days but the humidity still marks 98% why?
View: 8408   Answer: 1
Moisture level for lawn
Jan
Updated at 2020-08-08 08:43:43 UTC
Dear community
View: 10156   Answer: 1
Smart watering
Alejandro Foubelo
Updated at 2020-08-07 01:27:29 UTC
Hello, I set the app to run 3 manual programs on the odds day and I have the smart watering system active on all zones.
Will it skip my watering if there is rain in the forecast on an odd day?
View: 7266   Answer: 1
Fases
Joaquin
Updated at 2020-08-06 13:02:18 UTC
Hola! Acabo de instalar mi Netro al sistema de riego. El el equipo antiguo tenía dos fases, pero ahora la instalación para que funcionara me obligaba a utilizar la celda “M” y me he quedado con una sola fase para todo el riego. Como lo puedo solucionar?
View: 8489   Answer: 1
Confused about schedule
Bowie Xu
Updated at 2020-08-04 18:52:19 UTC
I am a new user here and just installed the Netro in my house. The “Smart watering” schedule seems very odd to me.
As you can see there are 2 rounds for each zone and the time of zone 4 is about an hour in one round. Is this normal ?
Bowie
View: 7668   Answer: 1
Home Assistant Integration
Giabbino
Updated at 2020-08-03 12:35:09 UTC
Lorenzo
View: 8466   Answer: 3
Watering "off the books"
wwhitfill
Updated at 2020-08-02 23:26:54 UTC
Right now the watering schedule the Netro program is using for my St. Augustine grass is killing my grass. I live in Dallas and Jully/August is brutal on lawns. If I water outside the schedule the program has established the schedule is changed. Is there anyway for me to water my with Netro and keep the smart watering schedule Netro has? Right now I by pass the Netro by manually engaging my water values, not using Netro.
Will
View: 7172   Answer: 1
STAN IN NEW JERSEY
Stanleyb3857
Updated at 2020-07-31 18:56:15 UTC
View: 7464   Answer: 1
Installation help
Francesco G
Updated at 2020-07-31 18:47:07 UTC
Greetings from Italy
this Monday I will receive my Netro Smart Irrigation controller and I have some concerns about the power supply.
On the YouTube video guide I saw there are 2 slots to put the power cables but I was only able to find a regular 24V power adapter with one single output.
Do I have to cut the power jack off and split the cables in order to put them in the controller?
thanks in advance for your help, can’t wait to become part of the Netro family!
this is the power adapter I ordered: Alimentatore 220 V – 24 V/1000mA https://www.amazon.it/dp/B00AWU8NUM/ref=cm_sw_r_cp_api_i_OBgjFbJ8Q41F1
this is the Netro device I ordered: Netro Sprinkler Smart Controller, WiFi, Meteo consapevoli, Accesso remoto, 12 Zone, w/o Adattatore di Alimentazione https://www.amazon.it/dp/B07DGT7ZK1/ref=cm_sw_r_cp_api_i_iCgjFbP0QZ4DH
View: 8460   Answer: 0
