Netro pixie Internet off
Andrea Zorgniotti
Updated at 2021-03-14 07:08:00 UTC
Hi, I'm the owner of a Netro 6 channel at my primary home where I use the smart watering function with no program, after 4 years I found the correct configuration and I'm really happy about the complete automation. In my vacancy home I bought a Pixie few weeks ago. I'm afraid the connection could be off when I'm not there. In the last weeks I set a program with 1 day on 5 min and the next off and the smart watering to check the rain and cancel the day raining. I would like to use the Pixie in the complete automation like in my principal home. So my question is what happen if I set only smart watering and then internet go off? Is it scheduled inside the Pixie a sort of program of watering that works anyway and the plant will receive water (even if in not an optimized way)?
View: 7125   Answer: 1
Foreca as weather provider
Fran Roman
Updated at 2021-03-09 21:21:35 UTC
Please add Foreca as weather provider! In Europe is much better than the available options on the app. Metro group is also a good option for your European customers like me.
View: 6784   Answer: 1
Skip watering moisture for Bermuda lawn
Fran Roman
Updated at 2021-03-09 20:30:13 UTC
Hi! I just installed my brand new whisperer, and I’m wondering which value I should configure for the skip watering functionality (80% by default). I have the perception that is too high for a Bermuda lawn.
View: 6668   Answer: 1
Selling our house - transfer sprite to new owners account
Tod Johnson
Updated at 2021-03-08 13:29:28 UTC
We are selling our house. How do we transfer the current sprite to the new owners without resetting all the settings?
View: 8396   Answer: 1
App non si configura con IPHONE 7 Plus iOS 14.4
Antonino Marretta
Updated at 2021-03-08 08:10:40 UTC
Salve a tutti, come da titolo la app durante la configurazione con smartphone in questo caso un IPHONE 7 PLUS con iOS 14.4 non riesce a completare l’accoppiamento con Netro , ho riprovato con smartphone Android con successo.
Ho fatto presente l’anomalia anche all’azienda costruttrice, la quale ci sta lavorando.
Chiedo a qualcuno di voi se ha avuto lo stesso problema.
View: 6219   Answer: 1
Sensor not starting
Joan Peiro
Updated at 2021-03-06 08:53:31 UTC
Good morning
I have received two days ago my new sensor. I am not able to start the sensor to proceed with the installation.
When I press the power button it makes a short flash in red after releasing but does not turn to white , blink or green.
Same effect when I press quickly  three times or six times.   It only produces a short flash in red.  I can not proceed with the installation as my app does not find the Netro wifi of the sensor as it is off.    I tried to leave the sensor under solar exposure for a full day with no change in the behavior.  Still just a short red flash after pressing the power button but nothing else.
Can you guide me how to solve the problem?
View: 8613   Answer: 2
How to add additonal members
Vijay Chidambaram
Updated at 2021-03-04 03:19:58 UTC
We have installed Netro Sprite system yesterday
we like the Netro app to manage the programs.
My question is this: How do i add additional members of the house the same access to manage the programs ?, such as altering zone level scheduling etc.
View: 8630   Answer: 1
Ignoring Restrictions for one zone
Brodie Lewis
Updated at 2021-03-01 02:55:53 UTC
Hey Team,
Have one zone that is connected to drippers in an undercover area with hanging baskets
Need to set a regular schedule for watering in this area, that ignores restrictions for this area, but still applies for other zones.
Is this available in the app at the moment?
View: 6642   Answer: 1
How many electro valves
javyto98
Updated at 2021-02-25 21:52:58 UTC
Hello I would like to know how many electro valves I can open at the same time?
View: 6509   Answer: 1
Zone says Loading
deleted_20260815225307_Gale
Updated at 2021-02-24 14:03:11 UTC
After the numerous power outages in Dallas last week, my sprinklers attempted to run this morning.   At its scheduled time, the zone shows "loading" but - no water.   ???
View: 6622   Answer: 1
explicit instructions on how to add weather station weather station, namely weatherunderground personal weather station
Joe Ryan
Updated at 2021-02-24 00:01:13 UTC
explicit instructions on how to add weather station weather station, namely weatherunderground personal weather station. How do you add station ID
View: 8677   Answer: 1
WiFi link
Benedetto
Updated at 2021-02-20 17:56:18 UTC
Hi, i would appreciate if someone could help me. I need to link the netro to the router without password, however the procedure need a password in any case: how can I do? Thanks for the support
View: 6745   Answer: 1
Valve sttoped
Carlos Jimenez
Updated at 2021-02-18 21:28:28 UTC
Hi, I will apreciate if someone can help me, I'm going crazy, becouse suddenly, one of the solenoid valve stopped after 10 seconds. But the app show that it is running. I changed the valve with a new one, but same 7-8 seconds after run, it stoppes. Pls help me! Thanks
View: 8354   Answer: 1
AMC
Updated at 2021-02-18 13:04:06 UTC
hello,
¿How Can I solve this issue?
APP version 2.5.3
View: 8657   Answer: 3
Turning off
Rony Z
Updated at 2021-02-15 13:58:39 UTC
View: 6997   Answer: 1
Smart Watering Algorithm
Updated at 2021-02-09 13:52:56 UTC
View: 7518   Answer: 1
Date Format
Brian Keenan
Updated at 2021-01-29 09:00:07 UTC
View: 6691   Answer: 1
Cancel
Awilda Betancourt
Updated at 2021-01-24 13:09:23 UTC
View: 6786   Answer: 1
Geron R
Updated at 2021-01-19 23:06:52 UTC
Please advise
View: 7209   Answer: 1
Maximum wire distance between controller and valves
Updated at 2021-01-16 14:20:49 UTC
Below is a chart indicating the maximum wire runs that can be used when installing AC solenoids and valves.
22 AWG: 600 feet
20 AWG: 700 feet
18 AWG : 850 feet
16 AWG: 1300 feet
14 AWG: 2000 feet
View: 10223   Comment: 0
