Updated at 2021-09-07 09:58:44 UTC
View: 9182   Answer: 1
Sean Eatch
Updated at 2021-09-01 01:08:02 UTC
View: 8792   Answer: 1
Updated at 2021-08-31 09:42:59 UTC
DEEP
EPA
REGULAR
FREQUENT
Any advice?
View: 9019   Answer: 1
Jean-François FOULT
Updated at 2021-08-29 17:46:56 UTC
Thanks for help
J Francois
View: 6622   Answer: 1
Manual watering stops before end of schedule
Patrice Kestenberg
Updated at 2021-08-29 16:13:57 UTC
I’ve got a sprite 6 system with 3 zones configured and no master valve
The watering stops before the end of planned schedule.
So I’ve deactivated all smart function to check, manual launch planned for 5 minutes.
It starts and after 15seconds it stops watering.
Any idea why?
View: 9045   Answer: 1
Whisperer not working right.
vkanaga
Updated at 2021-08-27 23:46:35 UTC
View: 8786   Answer: 1
Delete all schedules
Sharwell
Updated at 2021-08-27 14:41:04 UTC
I have added too many schedules on top of smart watering. How can I delete and start all over?
View: 9159   Answer: 3
Updated at 2021-08-26 14:17:28 UTC
View: 7427   Answer: 2
Adjusting Rain Fall
Mike Jones
Updated at 2021-08-24 09:19:23 UTC
Hi guys an girls.
Miky
View: 7151   Answer: 2
Updated at 2021-08-22 13:48:00 UTC
View: 7499   Answer: 1
Michael Gough
Updated at 2021-08-21 14:21:39 UTC
View: 8728   Answer: 1
javier58
Updated at 2021-08-21 02:52:17 UTC
View: 6430   Answer: 1
Insertar programss
Gaspar Morey
Updated at 2021-08-20 20:01:36 UTC
View: 6515   Answer: 1
Daniel Encinas
Updated at 2021-08-18 06:17:45 UTC
Hi all,
Thanks a lot,
Daniel
View: 8489   Answer: 1
% moisture
Julie Huynh
Updated at 2021-08-17 15:09:16 UTC
View: 10499   Answer: 2
Adaptador
Roberto Baltar
Updated at 2021-08-16 05:47:49 UTC
Hola.
View: 6656   Answer: 2
Sensor doesn’t work correctly
Paolo Sciarappa
Updated at 2021-08-14 20:06:25 UTC
The graphic is very poor.
 Any suggestion.
Thanks Paolo
View: 8767   Answer: 1
access to data
Updated at 2021-08-14 15:46:27 UTC
View: 7376   Answer: 1
Skip zone
the2brads
Updated at 2021-08-11 22:21:07 UTC
View: 6632   Answer: 1
Google Home
Michael Wheatley
Updated at 2021-08-11 15:45:28 UTC
View: 6950   Answer: 1
