stelio
Updated at 2022-05-13 00:33:14 UTC
Netro working fine last summer , I can seem
To get it to stay online . I reset the Netro and it work fine for the first 10 min … then it logs off and leave on zone open . I don’t know what to do ,To keep it online ?
View: 6532   Answer: 1
Netro not connecting
hawkshah
Updated at 2022-05-12 02:02:39 UTC
I have switched internet providers and now Netro won’t connect to att modem.  I have run through setup many times
View: 6026   Answer: 1
Updated at 2022-05-11 19:37:04 UTC
View: 6801   Answer: 1
Interface language
Bayoule Bayoule
Updated at 2022-05-11 19:31:03 UTC
Bayoule
View: 6425   Answer: 1
instruction manual of the Netro Sprinkler
Rolando Silvano
Updated at 2022-05-11 18:59:03 UTC
Where can I find the instruction manual of the Netro Sprinkler Smart Controller?
thank you
Silvano
View: 7874   Answer: 1
pollomito
Updated at 2022-05-10 19:31:57 UTC
Netro spark can be configured and used as timer if no wifi access point are available?
It is possible to use it by connecting directly mobile phone with spark without additional devices?
Thx
View: 8638   Answer: 2
Rain Delay Setting
Nicholas Lydakis
Updated at 2022-05-10 17:37:16 UTC
View: 7110   Answer: 1
Broken part
Jeremie Coderre
Updated at 2022-05-10 02:52:42 UTC
Hi there!
Thanks in advance!
View: 7837   Answer: 1
SoCal Mandatory "Once a Week" Watering
Jonathan B.
Updated at 2022-05-09 16:14:12 UTC
I've been given a notice that my county will require "Once weekly" watering beginning in June 2022. Will my Netro Sprite automatically adhere to this schedule or do I have to set it up myself?
View: 7776   Answer: 3
Rain Strategy
Luca Cerini
Updated at 2022-05-09 09:24:20 UTC
Luca
View: 7630   Answer: 1
Watering out of schedule time
Luca Cerini
Updated at 2022-05-09 09:14:09 UTC
Luca
View: 7653   Answer: 1
Jonas Lindholm
Updated at 2022-05-09 02:22:56 UTC
View: 6210   Answer: 1
How do I test the sprinkler system
themaguires4727
Updated at 2022-05-08 22:44:59 UTC
The instructions on page 12 of the Netro sprite quick start guide says I can use the ‘remote control’ feature to on the Netro app to turn on and off the sprinklers. I can’t find a ‘remote control’ setting on this app.
This entire system is making me feel like an idiot. Please help.
View: 6019   Answer: 1
Unable to save programs
Arnaud
Updated at 2022-05-08 13:27:21 UTC
Hello, when I program the repeated watering schedules, it does not appear in the calendar and nothing happens.
View: 5964   Answer: 1
mspenner3
Updated at 2022-05-06 00:09:34 UTC
View: 6313   Answer: 1
Smart watering -how do I know
John Kot
Updated at 2022-05-05 21:44:57 UTC
If I have smart watering enabled does it activate sprinklers when it (sprite) determines a need?  If so how do I prevent that when I happen to be mowing the lawn?
View: 8070   Answer: 1
No moisture reading
dsingelyn
Updated at 2022-05-04 17:59:14 UTC
Suggestions?
View: 8495   Answer: 3
Wifi reconnect issue
Giacomo
Updated at 2022-05-03 21:04:03 UTC
Hi All,
I'm a satisfied Italian customer of Netro Sprite 12 zones since 2019!
Recently I set my router to shutdown the wifi during the night, the Netro sprite it's the only one device that don't automatically reconnect when wifi come up in the morning, the white LED still blinking. To reconnect at the network, I need to phisically shutdown and power on the Sprite.
Is there a "trick" or an update to cover this issue? HW Version: 1.2 , Firmware Version 1.1.3
Thanks in advance.
Giacomo
View: 9927   Answer: 5
water valve does not work
Paolo Raviolo
Updated at 2022-05-03 15:55:47 UTC
I set up the pixie timer, everithing seems ok but the valve does not opens, nor with program nor in manual mode, no water at all.
can you help me?
View: 7896   Answer: 1
Rain stop
Javier Baruque
Updated at 2022-05-03 14:52:20 UTC
View: 7645   Answer: 1
