SMART SCHEDULE
Lorenzo Ignesti
Updated at 2022-06-13 08:14:03 UTC
Thank's
View: 7080   Answer: 1
Tech support
Robert Dambrosio
Updated at 2022-06-13 00:41:59 UTC
View: 9046   Answer: 1
Netro Spark question
Robert Dambrosio
Updated at 2022-06-12 20:59:09 UTC
View: 11347   Answer: 2
Insufficient watering
Gianluca Vettore
Updated at 2022-06-11 18:29:36 UTC
Thanks for your help.
View: 8156   Answer: 2
Rain restriction
Geron R
Updated at 2022-06-11 11:38:54 UTC
View: 8482   Answer: 1
Jen Morgan
Updated at 2022-06-10 10:56:50 UTC
View: 6997   Answer: 2
Netro light
beppezhome
Updated at 2022-06-09 14:46:24 UTC
View: 8352   Answer: 1
Sid Smith
Updated at 2022-06-06 21:47:14 UTC
View: 7544   Answer: 5
Minimum moisture content
Jason Pappas
Updated at 2022-06-05 03:34:37 UTC
View: 7358   Answer: 1
James Berg
Updated at 2022-06-05 01:03:46 UTC
View: 8907   Answer: 1
Matt Smith
Updated at 2022-06-04 19:01:43 UTC
View: 7474   Answer: 1
Jeff W
Updated at 2022-06-04 12:43:04 UTC
View: 7684   Answer: 1
Simon Clark
Updated at 2022-06-04 07:26:36 UTC
View: 7940   Answer: 2
Kurt H
Updated at 2022-06-03 20:40:34 UTC
View: 7985   Answer: 1
Move a Zone between Terminals
Gian Piero Pepino
Updated at 2022-06-03 12:13:40 UTC
Hello.
Is it possible to move a Zone, in my case: "Prato e back giardino" from Terminal 2 to Terminal 3 in a efficient way?
Let's say, for instance:  Copy Zone "Prato e back giardino" or Move "Prato e back giardino" from Terminal2 to Terminal 3, without being obliged to cancel the previous and reprogram all in a new Zone?
I've a problem with Terminal 2: the wire broke inside and I am not able to remove it ....
Thanx a lot
Gian Piero
View: 9441   Answer: 1
Sid Smith
Updated at 2022-06-02 22:21:42 UTC
View: 7761   Answer: 1
Reset rain delay to 0 (null)
Bruce Abbott
Updated at 2022-06-02 22:18:21 UTC
View: 7703   Answer: 1
PWS invalid
Giovanni Franceschini
Updated at 2022-06-01 19:16:43 UTC
Please enter a valid ID !
ISANREMO24
Thanks Giovanni
View: 8063   Answer: 1
Eric Berndt
Updated at 2022-06-01 19:03:43 UTC
View: 7561   Answer: 1
Eric Berndt
Updated at 2022-06-01 19:02:18 UTC
View: 7368   Answer: 0
