Rain stop
Javier Baruque
Updated at 2022-05-03 14:52:20 UTC
View: 8005   Answer: 1
Pixie shows "communicating" and timer counting down but valve not open?
Douglas Ely
Updated at 2022-05-01 15:54:22 UTC
When trying to use the Pixie to manually water the garden, I go to the Netro app and select the pixie. It shows "sleeping", 99%charged. I then select "manual run" and set a time. The app then grays out and says "communicating" as the timer begins counting down my preset manual time but the valve stays closed. Why? When does it open?
View: 9490   Answer: 3
Dhar Sawh
Updated at 2022-05-01 13:26:09 UTC
Dhar
View: 6993   Answer: 2
Location outside USA
Eduardo Prieto
Updated at 2022-04-30 09:45:16 UTC
I live in Spain and ubication selector do not let me specify my correcto location. I assume It is requieres to provide the Meteorological service the place where to predict weather, so if location is incorrect, the weather too and the watering planning is not optimized properly.
Please work It out un Next app releases.
View: 8224   Answer: 1
Incorrect rainfall accumulation
rwflower
Updated at 2022-04-29 16:35:33 UTC
I live in Katy Texas and have been using the Netro water controller in smart mode for over 2 years with no problems.  We received at least 1.5in of rain on the April 25, so I was dismayed to find my sprinkler system watering my yard on the morning of the 26th.  The rain graph in the app is showing 0.03in for the 25th and is clearly wrong.  I have tried changing to all the different weather providers, but the total rain accumulation doesn't change.  The frontal system that caused the rain passed over the entire area, so this is not a situation of local shower only affecting a localized area.
View: 8678   Answer: 2
Netro Whisperer
Fabrice GOUFFRAN
Updated at 2022-04-28 12:29:53 UTC
I am unable to have my new whisperer working. It doesn’t light on even after half a day under the sun.
View: 9179   Answer: 1
Activity not showing on ap
Mark Killeen
Updated at 2022-04-27 15:21:38 UTC
View: 7135   Answer: 1
J H
Updated at 2022-04-26 20:17:38 UTC
View: 6751   Answer: 1
Calendar won’t update
Yuanchao X
Updated at 2022-04-26 19:44:49 UTC
View: 6521   Answer: 2
Brian Brun
Updated at 2022-04-26 04:23:12 UTC
View: 7034   Answer: 1
Whisper Sensor
Ian Moore
Updated at 2022-04-26 02:55:10 UTC
View: 8608   Answer: 1
Updated at 2022-04-24 01:45:07 UTC
View: 15577   Comment: 1
doppia irrigazione
mauro croce
Updated at 2022-04-22 10:52:27 UTC
View: 8630   Answer: 1
Blinking light on my Netro
RMeador
Updated at 2022-04-21 01:20:07 UTC
View: 6329   Answer: 1
Davide M.
Updated at 2022-04-20 09:23:18 UTC
Good day all,
Thanks for help.
Davide
View: 7208   Answer: 1
ITA Translation
Davide M.
Updated at 2022-04-20 07:21:19 UTC
Hi all,
Best Regards,
Davide
View: 7004   Answer: 1
John Lillistone
Updated at 2022-04-19 11:26:49 UTC
View: 8107   Answer: 1
Netro lose wifi connection
Rob Rossi
Updated at 2022-04-19 09:22:12 UTC
If I restart the router,
how can it be solved?
View: 6699   Answer: 1
Wifi connection
Updated at 2022-04-18 11:31:15 UTC
View: 7298   Answer: 1
Alessandro Malaguti
Updated at 2022-04-18 10:04:06 UTC
I attach mp4 link
View: 6344   Answer: 1
