Phone number
Graham Corrett
Updated at 2023-04-05 13:07:22 UTC
Does anyone I have a contact/help number for this company possibly in the UK I’ve sent an email but no response!
View: 7879   Answer: 1
Michael Cayless
Updated at 2023-04-02 21:21:01 UTC
View: 7986   Answer: 1
Vincent Pollinzi
Updated at 2023-03-30 22:43:53 UTC
View: 7481   Answer: 1
Sprinklers not going off per schedule
Brian Brun
Updated at 2023-03-28 22:50:06 UTC
What are my sprinklers not going off per schedule? I have a schedule that it supposed to kick off Tuesday and Thursday. It is set to start at 6:00. It is 6:50 and it has not went off. I just had to manually run a cycle.
View: 8080   Answer: 1
No wifi connection
gdimofte@gmail.com
Updated at 2023-03-27 18:00:53 UTC
Dear Sir
Gabriel
View: 7537   Answer: 1
No 24V output?
Bigolin Davide
Updated at 2023-03-26 16:15:24 UTC
What can I do?
View: 7547   Answer: 1
Dont't start manual irrigation
Simone Teressi
Updated at 2023-03-26 11:39:57 UTC
I've checked that My netro isonline...but if i start a manual irrogation app say to me "communicating" and never begin to start..... If i turn off elecrticity and turn on again..... And then i go to manual  Irrogation and press start irrogation begin immediatly
View: 7772   Answer: 1
cannot connect my pixie to mi wifi with unifi Access point
christophe Minery
Updated at 2023-03-24 18:42:53 UTC
Someone can help me to connect to my unifi Wifi tm sensor Pixie ?
All goes OK unitl last step.... when it tell me that I connect connect to it
thanks
View: 8409   Answer: 1
Daily Backup of System
Zsolt Karman
Updated at 2023-03-20 08:35:47 UTC
Hi Team,
Regards, Zsolt
View: 9677   Comment: 2
Carlo Drago
Updated at 2023-03-18 18:55:41 UTC
Waiting your kind reply
Carlo
View: 8014   Answer: 1
Is Netro that smart?
Alessandro Alfei
Updated at 2023-03-16 00:53:44 UTC
why if Netro is so smart after months of learning with the whisperer still uses the "humidity to add watering" data set by me and doesn't create a custom program?  smartzone is in advanced level and regular mode.
View: 8312   Answer: 2
Whisperer is suddenly crazy
JM del Amo
Updated at 2023-03-15 15:39:31 UTC
After a lot of time working fine, suddenly whisperer is crazy. With no reason suddenly the humidity is at "0" and the temperatures are above "90". I have cleaned with water the whispers. I have cleaned the device with water but remains doing same random mistake-
View: 7804   Answer: 1
Feature request
Updated at 2023-03-15 12:51:04 UTC
View: 8297   Answer: 2
Updated at 2023-03-15 08:50:34 UTC
View: 8135   Answer: 1
Shedule
jmgrau
Updated at 2023-03-09 07:21:43 UTC
How can I program the app so that it does not do automatic shedule watering, only those programmed manually, I only want the gespa dalt and gespa baix dryers to irrigate 1 minute a day.
View: 7701   Answer: 1
Scheduled for March watering says next watering April
Texas AF
Updated at 2023-03-03 14:31:32 UTC
This is so damn frustrating to use.
I set to water every odd day.  Start in March.  It’s March 3rd no watering being done and the app says next watering April.
Any suggestions?   Been struggling with this app for two years now about to give up
View: 7736   Answer: 1
Notifications/Wunderground
Fernando AT
Updated at 2023-02-26 18:00:46 UTC
Hello!
1. How can I enable notifications (when watering, sensor moisture level…)?
2. Cannot set my Wunderground station ISANTA605.
View: 7729   Answer: 1
Vincent Coutinho
Updated at 2023-02-18 16:26:02 UTC
View: 11315   Comment: 2
Location Setting
ubo25
Updated at 2023-02-18 10:10:44 UTC
Please advise how I can change the location. I am staying in Windhoek, Namibia.
View: 7581   Answer: 1
Smart zone manual setup
Vieri Verze
Updated at 2023-02-18 08:31:43 UTC
I do not understand how many millimeters to set. I have microsprinklers of 4lt/h and 2lt/h. I thought to set to 4000ml/h but the max is 100ml/h.
How to calculate? I have a big terrace with 30 plants and various microsprinklers.
Vieri
View: 8152   Answer: 2
