valves under relay
Alek
Updated at 2023-04-22 17:48:29 UTC
View: 10432   Answer: 1
Area
Javier Domínguez
Updated at 2023-04-22 16:04:10 UTC
Hola,
Cuando estoy configurando las zonas me pide un valor de area, ¿en qué medida? ¿Metros cuadrados?
View: 8289   Answer: 1
farenheit to celsius
Santiago Moller
Updated at 2023-04-22 02:41:55 UTC
Hello, I need help to change the settings from Fahrenheit to Celsius in the app, I have a smart plant sensor.  Thank you
View: 8816   Answer: 1
Add user Error
Updated at 2023-04-21 09:26:43 UTC
View: 7830   Answer: 2
Pixie keeps disconnecting
Sang Peiris
Updated at 2023-04-18 12:44:42 UTC
View: 8223   Answer: 1
Multiple users
Norm Markworth
Updated at 2023-04-17 00:22:59 UTC
Norm
View: 9126   Answer: 2
dummy serial for testing
Updated at 2023-04-16 17:53:00 UTC
View: 8552   Answer: 1
Intelligent mode useless
Juan Lambea
Updated at 2023-04-14 15:51:37 UTC
View: 11177   Answer: 1
Matt Ward
Updated at 2023-04-14 13:57:11 UTC
Matt
View: 8649   Answer: 3
carlos davalos melgar
Updated at 2023-04-13 20:07:05 UTC
View: 10580   Answer: 1
Updated at 2023-04-13 20:06:57 UTC
View: 10815   Answer: 0
Updated at 2023-04-13 20:06:46 UTC
View: 8286   Answer: 0
Wasteful
David Maerzke
Updated at 2023-04-13 13:19:47 UTC
View: 7951   Answer: 1
Whisper will not factory reset!
Ross Brown
Updated at 2023-04-13 10:43:03 UTC
Hi I have had to send back my spark due to a problem with one zone not operating, I’m now trying to do a reset on my whisper, I have pressed the power button quickly 6 times, on numerous occasions and cannot get it to reset, any help would be much appreciated. New Spark arrived and working well, l just can’t seem to reset the Whisper no matter how many times I try the on/off 3 times. Are there any other action I could do or do I return it for a replacement?
View: 10227   Answer: 1
Suggestions and Question.
Maurizio Gianesin
Updated at 2023-04-12 15:08:32 UTC
Good morning.
I just started using Netro Sprite 8 zones out of 12 zones with two whisperers.
Congratulations for the App and the Web interface I'm using.
I have a concern about some trivial errors in the interfaces:
If you go to settings/preferences/SchedulingSetting
1.1 The Italian translation of "Two Frames" in "Due Cornici" makes me smile, it is better translated in "Due Cicli" or "Due Fasi". But my suggestion is also for English : it is my opinion that if instead of "Time Frames" and "Two Frames" you use "Time Phase" and "Two Phase" it is much better also for English and automatic translations free from misunderstandings.
1.2 Only in the App and not on the Web, the description of the two phases has "afternoon" under "morning" and vice versa.
Now I have a question:
I ask you for an explanation on Smart Scheduling.
I had set a lower limit of 10 C° and a Time Phase of 6:00 - 10:00. When I removed the 10 C° limit, the system did the same day a cycle at 23:58 instead of waiting for 6:00. why?
I hope I have been helpful and thank you for any response.
View: 8044   Answer: 1
Maximum watering duration for SPARK
Katarzyna Wrobel
Updated at 2023-04-11 22:55:50 UTC
Hi there :)
I want to set-up a watering duration for my desert garden (Phoenix, AZ). We should water our garden deeply and infrequently. So, I want to set-up a watering time of two hours. Unfortunately, the app has a maximum duration set to 60 minutes only. Any suggestions?
View: 7823   Answer: 1
Wiring multiple controllers
John Wright
Updated at 2023-04-10 19:05:31 UTC
I have an existing 18 zones irrigation controller which I am replacing. I require 2 controllers. No master valve or pump.
It is possible to connect both commons to the existing common connected to the 18 zones?
View: 10583   Answer: 1
Abraio
Updated at 2023-04-10 17:53:48 UTC
View: 7877   Answer: 1
Updated at 2023-04-10 15:17:46 UTC
Hi there
- seed type
- watering adjustement - EPA
- how tall to cut the grass
View: 8625   Answer: 1
Pixie linked to 2 iphone
Paolo S
Updated at 2023-04-10 13:29:30 UTC
Is it possible to control 1pixie with 2 iphone?
View: 8497   Answer: 1
