Delay settings
Roberto Pirovano
Updated at 2023-06-13 09:15:35 UTC
View: 7954   Answer: 1
Beau Cook
Updated at 2023-06-12 23:10:58 UTC
View: 7809   Answer: 1
Can’t open netro app
Marcos Sanz
Updated at 2023-06-12 16:35:22 UTC
View: 8693   Comment: 1
Apollon16
Updated at 2023-06-12 12:25:08 UTC
Apollon16
View: 10565   Answer: 1
Netro sprite
mekanicul Meku
Updated at 2023-06-11 09:43:07 UTC
View: 8078   Answer: 1
Certificate Expired - AGAIN!
AllenHome
Updated at 2023-06-11 06:42:24 UTC
View: 7669   Answer: 1
Certificate error
ventinovesette
Updated at 2023-06-11 06:03:25 UTC
View: 8191   Answer: 2
Problem with APP connection
Davide G.
Updated at 2023-06-11 05:49:55 UTC
View: 8069   Answer: 2
Srdjan
Updated at 2023-06-11 05:21:33 UTC
View: 8028   Answer: 2
Updated at 2023-06-10 17:50:24 UTC
View: 8206   Answer: 1
Whisperer sensor
Updated at 2023-06-10 17:39:10 UTC
View: 8599   Answer: 1
Netro sprite chpset.
Eduardo Pariente
Updated at 2023-06-09 18:15:34 UTC
Hello everyone.
Thanks you.
View: 7767   Answer: 0
Eduardo Pariente
Updated at 2023-06-09 18:15:24 UTC
Hello everyone.
Thanks you.
View: 7866   Answer: 1
Updated at 2023-06-09 06:07:25 UTC
2.Smart watering: Level basic
3.Smart-zone feature disabled
View: 23488   Comment: 12
Change Country
samhye
Updated at 2023-06-08 12:58:01 UTC
Hello all,
Many thanks.
View: 7800   Answer: 1
Adil Ridvan
Updated at 2023-06-08 04:44:28 UTC
Pros:
Cons:
Adil
View: 10926   Answer: 1
2 zones not working
Shahid Habib
Updated at 2023-06-05 13:39:04 UTC
Any help will be appreciated.
View: 8294   Answer: 3
Börke Titscher
Updated at 2023-06-04 08:32:03 UTC
Folks
View: 7824   Answer: 2
D Hitch
Updated at 2023-06-03 14:10:58 UTC
Thanks for any help.
View: 7739   Answer: 1
Power
nvenezia
Updated at 2023-06-02 18:10:49 UTC
View: 8514   Answer: 1
