Battery LED Blinking
E B
Updated at 2023-06-29 15:33:28 UTC
View: 9045   Answer: 1
COUNTRY PROBLEM
mario_chieppa
Updated at 2023-06-28 07:10:08 UTC
Hi, trying to register my geographical position (in Italy) I don't have the possibility to modify the fields in the photo, remaining in the USA.  For this reason the application time is totally wrong.  How can I fix?
Salve, cercando di registrare la mia posizione geografica ( in italia) non ho la possibilità di modificare i campi in foto, rimanendo USA. Per questo motivo l'orario dell'applicazione è totalmente sbagliato. Come posso risolvere?
View: 9065   Answer: 1
Updated at 2023-06-27 22:03:51 UTC
View: 8590   Answer: 1
Connection issue
Federica Musmanno
Updated at 2023-06-27 12:16:35 UTC
View: 8190   Answer: 1
Updated at 2023-06-27 08:48:51 UTC
View: 8744   Answer: 1
Updated at 2023-06-26 12:06:15 UTC
  1.  it's raining or
View: 8579   Answer: 1
Malfunzionamento durata irrigazione
MarcoPolinari
Updated at 2023-06-25 21:45:29 UTC
Buonasera,
quando avvio l'irrigazione, sia in manuale che in automatico, la centralina attiva per circa 2 secondi la zona e la pompa e poi si spegne, mentre  dal APP sembra che proceda tutto regolarmente.
View: 8505   Answer: 1
120 Sweet Bailey
Updated at 2023-06-23 23:14:09 UTC
View: 8096   Answer: 1
Ralph G
Updated at 2023-06-23 18:56:48 UTC
View: 8499   Answer: 1
Zones not watering
joefil
Updated at 2023-06-22 16:54:38 UTC
Your help is appreciated
View: 8127   Answer: 1
Start-end time not working
Fabio Silvestri
Updated at 2023-06-21 05:20:31 UTC
View: 8647   Answer: 3
Massimo Oldrini
Updated at 2023-06-20 07:57:16 UTC
Buongiorno,
L’apparato va sostituito?
View: 8195   Answer: 2
Disconnessione
Carlo Capraro
Updated at 2023-06-19 12:11:17 UTC
Grazie a tutti
View: 8089   Answer: 1
Updated at 2023-06-19 09:25:40 UTC
View: 8810   Answer: 2
Luis T
Updated at 2023-06-18 15:30:17 UTC
Any comments are welcome.
View: 11405   Answer: 3
Zone doesn't stay on
Brent S
Updated at 2023-06-18 02:05:28 UTC
Hi just installed a sprite 6. I can here zone turn on then immediately turns off but the timer is still running on the app. I can hear the water stop and start in each zone ; the app thinks it's watering but the valve closes. Same for all zones
Thansk
View: 8466   Answer: 1
Rainy day shut off
Updated at 2023-06-16 13:18:25 UTC
View: 8891   Answer: 1
zoe
Updated at 2023-06-15 00:40:38 UTC
Linda Lundgren
View: 8225   Answer: 1
Pixie-Z1-H - How to install?
kernel
Updated at 2023-06-14 15:54:05 UTC
  • I have received a new Pixie-Z1 and a hub
  • Downloaded the Netro iOS App from the UK app store
  • In the App I added the hub connecting through Bluetooth and configuring WiFi access for the hub
  • Hub shows constant green light
Now how can I add the Pixie-Z1 hose faucet to my account? The App only shows the option for the Pixie-1, which doesn't work because the Pixie-Z1 uses the Zigbee connection, not WiFi.
View: 11331   Answer: 1
No notifications
Khalid Mousa
Updated at 2023-06-14 03:25:18 UTC
View: 8725   Answer: 1
