My device is offline
carlos davalos melgar
Updated at 2023-09-17 18:50:32 UTC
i
How can I reconnect to Wi-Fi
the controller light is green
Please i need help
View: 8840   Answer: 1
David Solis
Updated at 2023-09-14 21:05:39 UTC
Thank you in advance
David
View: 8773   Answer: 2
smart zone advanced range
Leandro
Updated at 2023-09-12 17:37:36 UTC
Thanks for the reply
Leandro
View: 8290   Answer: 1
Change Wifi problem
Luciani Daniele
Updated at 2023-09-12 15:54:28 UTC
View: 8239   Answer: 1
Scheduling Issue
Steve Loesch
Updated at 2023-09-12 13:59:31 UTC
First.
Second.
View: 8451   Answer: 1
Soil moisture adjustment
Updated at 2023-09-12 01:34:23 UTC
View: 8932   Answer: 1
Whisperer stake cracked
Updated at 2023-09-09 20:22:46 UTC
View: 8904   Answer: 1
Arghhh, so horrible
Jake Tanner
Updated at 2023-09-09 16:24:29 UTC
View: 8324   Answer: 1
Irrigreen sprinklers
Updated at 2023-09-09 08:34:33 UTC
Combining with the whisperers
https://irrigreen.com/
View: 9376   Comment: 0
Parallel Run of watering
C He
Updated at 2023-09-08 08:39:13 UTC
Hallo and short question:
View: 8853   Answer: 2
smart watering
Diane Fetherolf
Updated at 2023-09-04 22:29:30 UTC
View: 8153   Answer: 1
C He
Updated at 2023-09-04 06:22:44 UTC
This is smart watering?
View: 8692   Answer: 1
Jacob Matheny
Updated at 2023-09-01 13:44:37 UTC
View: 8940   Answer: 1
Leandro
Updated at 2023-08-31 10:48:12 UTC
HI Support Team and All,
This wasn't written anywhere.
thank you all
Leandro
View: 8414   Answer: 2
Scott Yates
Updated at 2023-08-29 12:38:49 UTC
View: 8809   Answer: 1
Sensor offline
Tonycimo
Updated at 2023-08-28 21:29:20 UTC
How csn i solve it?
Czn i check snything?
View: 8163   Answer: 1
Please issue a good manual.
Mark Menzhausen
Updated at 2023-08-27 15:04:55 UTC
View: 10177   Comment: 1
Addind more than 3 Users?
scgrossengersdorf
Updated at 2023-08-27 11:07:02 UTC
Hello everyone,
WH
View: 8124   Answer: 1
Not connecting
Ali M
Updated at 2023-08-27 05:07:14 UTC
View: 8178   Answer: 1
Xavi
Updated at 2023-08-25 21:23:22 UTC
View: 8020   Answer: 0
