Problems with the internet
Morrie Wayne
Updated at 2019-07-15 16:50:35 UTC
We have a hot spot for our internet connection from Verizon. The hot spot keeps going off line and we don’t know what to do to correct it. Our Netro unit is in Florida and we are in Ohio. We don’t have any one close in Florida to help us with our problem. Might there be a inexpensive internet we might be able to acquire, or do you have another solution? We appreciate any suggestions you might have. We are happy with our Netro unit. Morrie Wayne. Address in Florida is. 1673 Abasco Ct. The Villages, Florida 32162. Address In Ohio is 18379 Squirrel Run Dr, Cleveland, Ohio 44130. My cell # is 440-856-9242. Thanks for any solution to our problems.
View: 9691   Answer: 2
HomeKit?
pintapass
Updated at 2019-07-15 03:55:15 UTC
View: 9288   Answer: 3
Fixing App "Contact Us" feature not working for Andorid
Updated at 2019-07-15 01:37:42 UTC
To the Netro android users,
Our Netro app crashes for android on sending messages though Settings->Support->Contact Us suddently. Our R&D are fixing this issue and we expect to have the fixes in place in a few days. We are sorry about the inconvenience.
If you have any questions, please write to us support@netrohome.com and we will make sure to deliver technical support in short time.
Thanks again for your support and trust.
View: 11958   Comment: 0
Location Based Watering Restrictions - Check-in Interval
Matt Grooms
Updated at 2019-07-14 18:58:52 UTC
One of the great features of Netro is it's ability to look up my local (city/state) watering regulations, and apply them to my watering schedule. Bravo Netro!
Months ago, when I installed my Netro controller it looked up the then current (Stage-One) restrictions, and applied them to my watering schedule. However, since that time the watering restrictions have been eased (Year-Round restrictions) , and I'm allowed to water any day of the week. Well, Netro did not follow the changes and is still applying the old restrictions.
I attempted to trick Netro into rereading my local restrictions by turning the feature off, then back on. No luck.
So the questions are:
1) How often does a Netro Controller check the cloud database for updated watering restriction for it's location?
2) How often does Netro Central (you guys) check with communities for watering restriction updates and update your database so that deployed Netro controllers get accurate rules to apply?
I can see where it might be hard to keep up with small communities and rural areas, but my location (San Antonio, Texas, USA) has almost two-million people in the area. A single update on your part would provide a potentially large number of Netro users with current watering restriction information.
Matt
View: 14960   Answer: 1
No light
Gilbert Lee
Updated at 2019-07-14 15:37:53 UTC
View: 7997   Answer: 1
Netro + Netatmo
Luca Magnani
Updated at 2019-07-14 07:42:29 UTC
Good morning
I have a netatmo weather station,
it would be nice to connect it to read the weather data precisely for my area.
Thank you in advance
View: 15487   Answer: 1
How do you stop the watering
Rick Jones
Updated at 2019-07-13 16:02:14 UTC
View: 7737   Answer: 1
Updated at 2019-07-12 15:05:29 UTC
View: 10290   Answer: 1
Rod Timby
Updated at 2019-07-11 18:14:39 UTC
View: 9083   Answer: 1
Rod Timby
Updated at 2019-07-11 18:09:47 UTC
View: 8915   Answer: 0
Whisperer Test
Dan Leng
Updated at 2019-07-10 18:29:27 UTC
View: 10052   Answer: 2
Spanish language for control
sorondo
Updated at 2019-07-09 09:24:52 UTC
Jcgc
View: 8516   Answer: 1
How to change zip code in the addres in the setting/controller
sorondo
Updated at 2019-07-09 07:50:41 UTC
How to change zip code in the addres in the setting/controller?
By mistake I nitroduced a wrong zip code in the address of the controller... How can I change it? Do I have to remove the controller and inmediatelly to add a new one? Thanks.
Jcgc
View: 8795   Answer: 3
Doug Clark
Updated at 2019-07-07 18:06:07 UTC
This isn’t AI!
View: 8540   Answer: 1
Updated at 2019-07-07 14:40:49 UTC
View: 10824   Answer: 1
Reset Moisture Level
firewally
Updated at 2019-07-06 14:06:03 UTC
View: 8416   Answer: 1
Home Assistant
David
Updated at 2019-07-06 09:33:48 UTC
View: 8673   Answer: 1
Saurik
Updated at 2019-07-04 07:12:42 UTC
View: 9569   Answer: 1
Smart watering
John Jessee
Updated at 2019-07-03 22:25:57 UTC
View: 7894   Answer: 1
Forecast provider for Italy
Gabriele Gianello
Updated at 2019-07-03 11:53:03 UTC
View: 9126   Answer: 1
