Schedule setup
Rich Christenson
Updated at 2019-09-21 14:51:31 UTC
View: 7844   Answer: 1
Unit measurements
Homestead One
Updated at 2019-09-17 20:29:09 UTC
View: 7803   Answer: 1
Updated at 2019-09-17 12:12:15 UTC
View: 9727   Answer: 1
Feature request
Tony D.
Updated at 2019-09-12 20:32:30 UTC
Tony
View: 8367   Answer: 1
Tony D.
Updated at 2019-09-09 12:57:04 UTC
View: 8741   Answer: 1
Windows 10 APP or web page
Emanuel Di Giusto
Updated at 2019-09-06 19:46:57 UTC
View: 7858   Answer: 1
Manual run time screen
Rich Christenson
Updated at 2019-09-06 10:25:49 UTC
View: 8262   Answer: 1
New Whisper not reporting
Updated at 2019-09-04 17:11:14 UTC
I recently ordered a second whisper and installed it the same way as the first one I received (which is still working fine)  It connects just fine and I can even change the color of the LED for a while.  But it reported only once to the app and that was it.  I have tried reconnecting it to WiFi, I even deleted it in the app and reinstalled it with no success.  After the initial connection it seems to just stop working.
View: 9937   Answer: 1
Ron White
Updated at 2019-09-04 16:44:17 UTC
View: 8137   Answer: 1
Power Transformer
DeanH
Updated at 2019-09-04 02:31:34 UTC
I have my controller in my garage here in the desert.  The transformer seems very hot to the touch.  Is this a problem??
View: 10915   Answer: 3
System went basqerk?
Ron White
Updated at 2019-08-27 01:21:18 UTC
View: 8121   Answer: 2
watering sequence
Gérard GALBOIS
Updated at 2019-08-26 18:23:46 UTC
It is unfortunatly not possible to change  in which ordre the watering will act.
for exemple I need to water zone 5 after zone 7 because zone 7 is at a higher level than the electro valve and remaining water pressure, after watering is stopped,  is to strong and prevents the valve to close . by watering supplemantary  zone 5 which is lower the pressure diminishes ans the valve of zone 7 closes..
View: 7793   Answer: 1
How does a whisper sensor work with a drip system?
L F
Updated at 2019-08-25 23:46:33 UTC
I have a couple whisper sensors monitoring my lawn and drip system.   I understand how they can monitor the soil in my lawn but I’m wonder how the whisper works on my drip system as it doesn’t see the moisture that’s added to the soil(the emitter isolates the water to the plant) or the rate the plants use it like the one in the lawn does.  I’m assuming it’s just estimating like the Netro would on it’s own.  Is there much value to using a whisper on a drip zone?
Yellow triangle with ! Inside
Michael Pakalolo
Updated at 2019-08-24 16:15:54 UTC
What does the yellow triangle with the ! mean next to the schedule
View: 9353   Answer: 1
Weather Provider
Martin Müller-Zantop
Updated at 2019-08-22 10:57:44 UTC
Can you please explain to me the big difference of the next watering days using different weather providers? As you can see in my print screens the data of temperature and humidity are nearly the same. With one provider next watering cycle will be in 2 days and with another in 11 days.
Thank you for your comments
Martin
View: 8691   Answer: 2
Smart watering once a week?
Andrea D.
Updated at 2019-08-22 05:51:16 UTC
Hello there,
I'm new to netro and I tried to setup smart watering but the data I provided it will do it just once a week.
How is it possible? Is it safe to water just once a week?
View: 7628   Answer: 1
Internet connection problems
danadcock
Updated at 2019-08-20 14:07:11 UTC
I have had a lot of trouble with losing netro's connection with internet. My old router failed so I replaced it with an expensive mesh wifi system which provides wonderful service to everything I have tried to connect except my Netro! I have now discovered that it will not work with anything but 2.4 GHz wifi. The new wifi does not provide 2.4 connection. Is there a workaround for this? Or do I have to throw out my new state-of-the-art $400 5 GHz wifi to get my somewhat obsolete $100 Netro to work?
View: 9685   Answer: 2
Why water twice a day?
Ron White
Updated at 2019-08-19 19:05:12 UTC
View: 7847   Answer: 2
Drain
Moe
Updated at 2019-08-17 23:31:13 UTC
View: 8041   Answer: 1
Feature Request: API
cjmulk2
Updated at 2019-08-17 03:18:34 UTC
View: 8627   Answer: 3
