Whisperer settings
Manuel Roca
Updated at 2019-11-30 23:47:29 UTC
I’m wondering how many whisperer units I need to have if I my garden has 8 zones. Do I have to get 1 per zone?
View: 9697   Answer: 1
Works in Uruguay?
Sebastian Diaz
Updated at 2019-11-26 20:39:14 UTC
Hello I bougth my first netro sprite but i can not find the country Uruguay and i the smart not work correctly, how i can resolve this issue?
View: 9833   Answer: 1
Smart zone enabled
Steve Kalani
Updated at 2019-11-25 18:36:19 UTC
View: 7651   Answer: 1
Manuel Roca
Updated at 2019-11-22 17:20:29 UTC
This is an easy question
View: 8370   Answer: 2
Black Friday
John Mayer
Updated at 2019-11-22 10:40:22 UTC
Hello Netro, will you have a black Friday offer?
View: 16149   Answer: 1
Daylight savings
Craig Neidle
Updated at 2019-11-13 18:34:27 UTC
Haow can i change this?
View: 8401   Answer: 1
How to replace an old controller with more than 12 zones
Updated at 2019-11-06 09:20:19 UTC
If your old controller has more than 12 zones, you will need to have 2 Netro controllers to replace it. Please follow the diagram below to safely wire the 2 controllers:
Now you can use the 2 C slots for the common wires and the 2 sets of 1-12 slots for the zone wires. If you do not have a master valve or pump, just ignore the orange wires.
IMPORTANT: the blue wire has to be connected to the left 24VAC on both controllers and the yellow wire has to be connected to the right 24VAC on both controllers.
Please contact us if you need the wire connectors shown in the picture.
View: 12313   Comment: 0
Riego netro para tepes
Manuel C
Updated at 2019-10-23 09:36:27 UTC
Hola,
View: 12500   Answer: 1
What about blowout?
Burghardi
Updated at 2019-10-18 02:06:15 UTC
Why doesn’t this one?
View: 8295   Answer: 2
Sangjin Lee
Updated at 2019-10-17 03:41:11 UTC
View: 8290   Answer: 1
Brian Hobbs
Updated at 2019-10-15 01:58:49 UTC
View: 9492   Answer: 1
Weird watering plan
Manuel Roca
Updated at 2019-10-12 11:34:00 UTC
View: 8002   Answer: 1
Installation Direct to pump
Tim Foster
Updated at 2019-10-03 11:23:32 UTC
I have the following:
View: 10116   Answer: 2
sqwu
Updated at 2019-09-30 13:51:09 UTC
View: 8511   Answer: 1
Nguyễn Vinh
Updated at 2019-09-30 06:46:55 UTC
View: 10000   Answer: 2
hanz.blatt@gmail.com
Updated at 2019-09-29 13:59:02 UTC
View: 15093   Answer: 2
Cold winter season and whisperer ?
Yves Desrosiers
Updated at 2019-09-26 11:12:56 UTC
We have to take back inside our home the whisperer when the cold season is back I guess ? At what  exterior tempeture we should do this ?
View: 11482   Answer: 3
Solid white light after install - HELP
Carlos Oliveira
Updated at 2019-09-25 20:29:08 UTC
I have just replaced a Rain bird image 6 by the Netro Sprite and I am using it's power supply.
The problem is that once I connect it after first install it gets to solid white light. I press reset shortly or even for 8 seconds but nothing changes.
Can someone help me ?
View: 9814   Answer: 1
Ip address
Kris Y
Updated at 2019-09-25 20:13:08 UTC
View: 8284   Answer: 1
Tony D.
Updated at 2019-09-24 21:08:17 UTC
Hello everybody,
View: 8537   Answer: 1
