Rainfall correction
cjmulk2
Updated at 2019-08-17 03:15:16 UTC
Feature request: On the discover screen, please allow rainfall correction further back than yesterday and allow setting the correct rainfall amount to zero. (Lowest it goes currently is 0.1).
View: 9290   Answer: 1
Alexa skill
Tony D.
Updated at 2019-08-16 23:42:33 UTC
What do I need to search for?
View: 8175   Answer: 1
Updated at 2019-08-16 02:54:33 UTC
View: 8383   Answer: 1
Whisperers firmware update
Updated at 2019-08-15 16:25:53 UTC
When is it going to be released?
View: 8802   Answer: 0
Zones run at the same time
Rich Christenson
Updated at 2019-08-15 11:05:09 UTC
View: 9920   Answer: 3
Removing plant sensor
Alessia
Updated at 2019-08-14 20:41:19 UTC
Hello, how can i remove the plant sensor which i added for error?
View: 9436   Answer: 1
One day restriction
Lou Infeld
Updated at 2019-08-12 21:49:14 UTC
View: 7859   Answer: 1
Unexpected smart schedule
Tony D.
Updated at 2019-08-12 09:35:56 UTC
- zone 1: 6:00 16 min.
- zone 2: 6:17 15 min.
- zone 1: 6:46 16 min.
- zone 2: 7:02: 15 min.
UPDATE
Thank you in advance,
Tony
View: 8616   Answer: 1
Update application
Anyhony Harwood
Updated at 2019-08-11 11:58:55 UTC
View: 7527   Answer: 1
Spanish translation
Juan P
Updated at 2019-08-10 21:48:16 UTC
View: 9126   Answer: 3
Zip code
Homestead One
Updated at 2019-08-10 11:09:29 UTC
View: 7655   Answer: 0
Suport MQTT? Suport REST API?
Sergio Albarran Rebull
Updated at 2019-08-09 14:25:13 UTC
Suport MQTT?
Suport REST API?
Thanks in advance...
View: 9230   Answer: 5
Netro on Apple Watch
Updated at 2019-08-07 06:39:26 UTC
To the Netro community:
2.Rainfall adjustment
View: 55781   Comment: 15
Plant Sensors Monitoring Multiple Zones
Updated at 2019-08-07 06:39:15 UTC
We recently have launched an update for the Netro app on App Store and Google Play. In the newest version of the app, we allow one sensor to monitor up to 3 zones but the user needs to make sure the zones have similar environmental conditions.
Please upgrade your app to the newest version and go to Settings->Sensors, select a sensor, go to Zones and select the zones you would like to monitor.
After saving the changes, you can go to the Home page and check the topsoil moisture level of your zones reported by sensor.
Please feel free to explore other new and exciting features that we just added :
1.Support Apple Watch
(only available for iOS )
2.Support Weather Underground PWS
3.Rainfall adjustment
View: 13276   Comment: 3
Runs for 9 hours at a time
Cindy Luvender
Updated at 2019-08-07 00:27:20 UTC
View: 7942   Answer: 1
itsthesun
Updated at 2019-08-06 20:42:23 UTC
View: 8075   Answer: 1
Sprite doesn't open valve
Tony D.
Updated at 2019-08-06 20:38:31 UTC
View: 10061   Answer: 1
Updated at 2019-08-06 11:03:17 UTC
View: 8068   Answer: 1
changing watering zone times?
Updated at 2019-08-06 01:53:14 UTC
View: 7980   Answer: 1
Install
Daniel Alman
Updated at 2019-08-05 15:17:08 UTC
View: 7783   Answer: 1
