Weather Company API- Revenue stream for Netro
Updated at 2019-04-20 12:58:20 UTC
It is my understanding that you could restore our ability to pull data into netro from our individual weather stations. This would require paying for the API, which you could mark up 20% and offer a paid option to netro clients. $3.99 a year, for example, would be totally worth it to get accurate information to my sprinkler controller. As I have outlined in a previous post, dark sky has proven to be wildly inaccurate. It's Miss estimates rainfall by at least 50%, on average, and is within three degrees plus or minus on high temperature only about 50% of the time.
View: 10344   Answer: 4
Updated at 2019-04-20 12:21:46 UTC
Mr Bad Example
View: 9533   Answer: 1
Suggestion: Sunrise smart watering
Mark S
Updated at 2019-04-15 13:39:43 UTC
I think Rachio adjusts the watering schedule with sunrise to have all zones completed as the sun is coming up. Is this something you intend to add? I think this will come in handy with the heat of summer.
View: 9223   Answer: 1
Smart Watering Basic with a schedule watering adjustment
Barry Perfect
Updated at 2019-04-13 17:00:37 UTC
If I have a zone set to Smart Watering - Basic with a schedule to come on for 30 minutes, will the smart watering adjust the duration of the watering based on the weather (say 10 minutes when it’s cool, the full 30 minutes when it is hot), or just turn it off/on based on the 5mm expected rain threshold?
Barry
View: 8871   Answer: 1
Smart home integration
Matt Griste
Updated at 2019-03-29 22:29:57 UTC
View: 9580   Answer: 2
MAC address
Lee Hill
Updated at 2019-03-29 15:45:44 UTC
View: 9402   Answer: 1
windy conditions
Magnus Swenson
Updated at 2019-03-27 20:05:53 UTC
The setting for windy conditions is great.
However the zones that includes drip irrigation doesn’t get impacted by winds (since they’re often under dirt/mulch etc) usually rotors and nozzles would be impacted . Is there a way not to include in ground drip irrigation on windy conditions?
View: 9285   Answer: 1
controller firmware
Magnus Swenson
Updated at 2019-03-27 19:55:40 UTC
Does the controller update its own firmware automatically on a specific schedule or you push out when needed?
View: 9934   Answer: 1
Not able to water
Updated at 2019-03-27 13:18:49 UTC
View: 9746   Answer: 1
charu
Updated at 2019-03-21 16:27:21 UTC
View: 8794   Answer: 1
Instructions about Replacing Hunter System
Updated at 2019-03-20 08:08:36 UTC
Replacing Hunter system
This page lists some instructions about replacing the common types of Hunter system with Netro smart watering controller.
Example 1:
To replace this controller with Netro smart watering controller, please follow the instructions.
The white wires are the common wires which should be connected to the C slots in Netro. Then the zone wires (1,2,3, .. 12) are directly mapped to the 1, 2, 3 .. 12 slots in Netro. The last step is to connect the power (the ground wire is not needed for Netro) then you should be good to go. The power adapter wires are the 2 yellow wires on the left side.
The green one below the yellow wires is the ground wire which is not needed for Netro.
The copper wires are rains sensors which are not needed for Netro either because Netro gets the weather information from WiFi network.
Example 2:
For this system, please connect the white wire to any one of the C slots in Netro. You can leave the M slot of Netro smart watering controller and one of the C slot unconnected.
The last step is to connect the power. The power adapter wires are the 2 yellow wires on the left side.
SEN are rains sensors which are not needed for Netro either because Netro gets the weather information from WiFi network.
Example 3:
Please connect the white wire to any one of the C slots in Netro. You can leave one of the C slot unconnected.
This system has 3 wires which connects to 24v lines. To replace it with Netro smart watering controller, you can use the existing 24V power(the yellow wires) for your Sprite. It looks like the thinner 2 are the ones but you might just want to try them on Sprite. Or you can use a voltage meter to determine.
If the thinner yellow wires turn out to be the power, than I think the thinner white wire is the common wire which should go to the C slot in Sprite.
Example 4:
You should connect the white wire(currently on RS) to one of the C slots in Sprite.
You do not need to connect the black wire(currently on C) and the brown wire(currently on RS). RS terminal is the rain sensor. Therefore, you do not need to connect these wires.
Example 5:
The white wire is the common wire which should be connected to one of the C slots in Netro. The power adapter wires are the 2 black wires on the left side.
Example 6:
The white wires is the common wires which should be connected to one of  the C slots in Netro. The power adapter wires are the two black wires on the left side.
The green one below is the ground wire which is not needed for Netro.
You do not need to connect the rain sensors because Netro get the weather forecast through WiFi.
Example 7:
You do not need to connect the blue one (remote). You can just leave it dangling but please use the tape to cover the metal head. The remote feature in Sprite is through the WiFi.
I am not sure about the red and white one. These are the two AV power wires. Normally there is only one wire for AC1 and one wire for AC2. In your case, it looks like the AC power is also sent to another device. The safest way to handle this is to keep this original connection. You might want to "noodle" the wires and insert them into the two "24 VAC" slots in Sprite. Please check out this connector for wire junctions:
https://www.amazon.com/Gardner-Bender-25-AWC-Assortment-Resealable/dp/B000F5TTE8
View: 29603   Comment: 24
Instructions about Replacing Orbit System
Updated at 2019-03-20 08:07:49 UTC
Replacing Orbit system
This page lists some instructions about replacing the common types of Orbit system with Netro smart watering controller.
Example 1:
 Replacing Orbit model with Netro (model 57114-WT2X 4 stations)
You have 2 common wires and you can insert them into the 2 C slots in the Sprite controller.
You have 4 zones and you can use the 1-4 slots in Sprite to connect the 4 zone wires.
The last step is to hook up the 2 power wires using the Netro power adapter.
View: 14354   Comment: 0
Instructions about Replacing Toro System
Updated at 2019-03-20 08:07:29 UTC
Replacing Toro system
This page lists some instructions about replacing the common types of Toro system with Netro smart watering controller.
Example 1:
Toro model gk212-04
1. Connect the 2 white wires to the C slots, one on the left and the other on the right which is now occupied by a red one.
2. Move the red wire(currently on C slot) to M slot because it is for your master valve.
3. The last step is to connect the power then you should be good to go.
Example 2:
Toro IC 8.
The first slot of your current controller is master valve which should be connected  to "M" slot of Netro. The two wires in the second slot are common wires should be connected to the 'C' slot of Netro. The last step is to connect the power then you should be good to go.
Example 3:
Toro Model 53765 6 zones
The red and white wires are the commons wires and should go to the two "C" slots in Netro Sprite controller. You do not need to connect the gray and black wires as they are the power wires for the old controller.
View: 11722   Answer: 0
Instructions about Replacing Rainbird System
Updated at 2019-03-20 08:06:44 UTC
Replacing Rainbird system
This page lists some instructions about replacing the common types of Rainbird system with Netro smart watering controller.
Example 1:
 The common wires which should be connected to the C slots in Netro.
The Sprite controller does not need the ground wires. It does not need the rain sensor either. You can leave the M slot unconnected.
Example 2:
The COM wire goes to any C slot in Sprite.
The M slot will be empty because you do not have master valve.
The two red wires on the left go to the two 24 VAC slots.
Others are straightforward.
Example 3:
1. the COM wire in RainBird go to any of the C slots in Netro
2. The 1-6 zone wires in RainBird go to Slot 1-6 in Netro
3. Use the power adapter coming with the package for Netro
Other wires you can disregard them.
Example 4:
12(blue) and 11(red) go to the two AC slots on the right side for Netro. 10(white) goes to any one of the C slot in Netro. 9(black) goes to the M slot in Netro. 8-1(red) go the ZONES in Netro. You can leave the green wire (GND) open. The two leads from the power adaptor go to the two AC slots.
View: 16635   Comment: 0
Updated at 2019-03-20 08:03:05 UTC
Replacing old system
Example 1:
I check the pictures.
OLD                 Sprite
COM                any C slot
1                     1
2                     2
3                     3
4                     4
Example 2:
Example 3:
Example 4:
Other wires are not needed.
Example 5:
View: 10217   Answer: 0
Updated at 2019-03-19 04:52:48 UTC
View: 12644   Comment: 0
Overriding smart waterinh
mvernia
Updated at 2019-03-17 20:46:27 UTC
View: 8963   Answer: 1
Scot and Michelle Cowan
Updated at 2019-03-03 17:04:51 UTC
View: 10315   Answer: 1
Nathan Anderson
Updated at 2019-02-13 03:53:31 UTC
View: 9532   Answer: 1
Tim Cox
Updated at 2019-02-02 01:35:59 UTC
View: 9483   Answer: 3
