Interface language
Bayoule Bayoule
更新时间 2022-05-11 19:31:03 UTC
Bayoule
浏览: 6788   回复: 1
更新时间 2022-05-11 19:37:04 UTC
浏览: 7102   回复: 1
Netro not connecting
hawkshah
更新时间 2022-05-12 02:02:39 UTC
I have switched internet providers and now Netro won’t connect to att modem.  I have run through setup many times
浏览: 6325   回复: 1
stelio
更新时间 2022-05-13 00:33:14 UTC
Netro working fine last summer , I can seem
To get it to stay online . I reset the Netro and it work fine for the first 10 min … then it logs off and leave on zone open . I don’t know what to do ,To keep it online ?
浏览: 6836   回复: 1
Invalid station id WU
Richard B
更新时间 2022-05-13 00:47:24 UTC
浏览: 6619   回复: 1
Invalid station WU
Bayoule Bayoule
更新时间 2022-05-13 03:51:52 UTC
JM
浏览: 6788   回复: 1
How do I set on/off times?
Rikki Swin
更新时间 2022-05-13 17:37:43 UTC
How do I program the on/off time on the new software? I need to have gaps between zones for pressure to rebuild. The new software is not intuitive!!!
浏览: 6321   回复: 1
Manual Run
Dick Goddard
更新时间 2022-05-13 20:53:29 UTC
Please help
浏览: 7015   回复: 2
Good evening It but impossible to connect me netro tells me to make sure that the correct WIFI password is entered ... I have been trying to appear for 4 hours
GERMONT Alain
更新时间 2022-05-13 23:02:49 UTC
Good evening
浏览: 7136   回复: 3
Programación
jmgrau
更新时间 2022-05-15 05:30:10 UTC
Buenos dias, como tengo que programar para que la schedule no actúe solamente funcionen los programas que yo programe.
Si programo algún programa, ahora me sale la schedule también.
浏览: 8443   回复: 1
Offline since a couple of days
Daniel Torres
更新时间 2022-05-15 10:01:39 UTC
Since a couple of days my Netro is offline. I have connected to my Netro to add the wifi password again and rebooted the router 3 times but still offline.
浏览: 6778   回复: 1
Sprinklers only turn for a few second
Gabriele Wiel
更新时间 2022-05-15 11:11:42 UTC
good morning
just installed his transformer burned out I had an electrician install a new transformer, now it works but the sprinklers only turn on for a few seconds, what can it be
This is a photo new transformer
浏览: 8529   回复: 2
Weather .
Gianluca De Virgilio
更新时间 2022-05-15 17:39:09 UTC
Good afternoon. The Weather forecast avvailable are absolutelly not real. What can I do?
Could you help me to con figure weather underground?
浏览: 7051   回复: 2
Fabrice GOUFFRAN
更新时间 2022-05-16 18:02:23 UTC
Good morning, Italy is my home, I recently started to use Netro replacing an old watering device I have used for several years, so far happy with my choice. I have one whisperer sensor device and I need 2 more but they are sold out on your online website, Amazon italy is also sold out with no forecast on new availability, where can I buy ?. Thank you.
浏览: 9077   回复: 2
Restrictions do not include minute limits
Cheryl Michael
更新时间 2022-05-17 03:03:27 UTC
I cannot find a way to reduce the minutes each station is watered. All stations on Eco boost. And some water almost an hour total (in 3 sessions) on allowed watering days. Our local So Cal restrictions are 10 minutes per station! How do I restrict  this?
浏览: 6480   回复: 1
Bruno
更新时间 2022-05-17 19:49:58 UTC
浏览: 7236   回复: 1
Home Tab
bdcfam
更新时间 2022-05-18 04:36:33 UTC
浏览: 6965   回复: 1
Text in gray
Ignacio Sánchez
更新时间 2022-05-18 11:26:32 UTC
浏览: 6945   回复: 1
Pixie automatic water
Shirley Johnson
更新时间 2022-05-18 18:20:36 UTC
My pixie won’t find my Wi-Fi. I’ve rebooted my router but didn’t help.
浏览: 8482   回复: 1
Emilio
更新时间 2022-05-20 17:05:31 UTC
Buenas tardes,
Pronóstico o expectativas.
浏览: 6579   回复: 1
