App crash
Jiang Zheyue
更新时间 2022-04-14 14:34:05 UTC
浏览: 7089   回复: 1
Scott Gustafson
更新时间 2022-04-14 22:26:18 UTC
浏览: 8666   回复: 1
idpitt
更新时间 2022-04-16 13:50:17 UTC
What am I missing?
浏览: 7059   回复: 1
Watering days
更新时间 2022-04-16 18:22:19 UTC
Home display is correct and shows Last watering the day before at the date and time in the program (watering planned everyday) but under Discover many days are shown as if there has not been any irrigation.
What could be the reason why ?
浏览: 8747   回复: 2
Feature Request
Tod Johnson
更新时间 2022-04-16 18:22:20 UTC
浏览: 6354   回复: 1
Gaspare Miceli
更新时间 2022-04-18 06:23:55 UTC
浏览: 11038   回复: 1
Alessandro Malaguti
更新时间 2022-04-18 10:04:06 UTC
I attach mp4 link
浏览: 6165   回复: 1
Wifi connection
更新时间 2022-04-18 11:31:15 UTC
浏览: 7110   回复: 1
Netro lose wifi connection
Rob Rossi
更新时间 2022-04-19 09:22:12 UTC
If I restart the router,
how can it be solved?
浏览: 6508   回复: 1
John Lillistone
更新时间 2022-04-19 11:26:49 UTC
浏览: 7909   回复: 1
Davide M.
更新时间 2022-04-20 09:23:18 UTC
Good day all,
Thanks for help.
Davide
浏览: 7019   回复: 1
ITA Translation
Davide M.
更新时间 2022-04-20 07:21:19 UTC
Hi all,
Best Regards,
Davide
浏览: 6828   回复: 1
Blinking light on my Netro
RMeador
更新时间 2022-04-21 01:20:07 UTC
浏览: 6140   回复: 1
doppia irrigazione
mauro croce
更新时间 2022-04-22 10:52:27 UTC
浏览: 8433   回复: 1
Whisper Sensor
Ian Moore
更新时间 2022-04-26 02:55:10 UTC
浏览: 8417   回复: 1
Brian Brun
更新时间 2022-04-26 04:23:12 UTC
浏览: 6857   回复: 1
Calendar won’t update
Yuanchao X
更新时间 2022-04-26 19:44:49 UTC
浏览: 6338   回复: 2
J H
更新时间 2022-04-26 20:17:38 UTC
浏览: 6562   回复: 1
Activity not showing on ap
Mark Killeen
更新时间 2022-04-27 15:21:38 UTC
浏览: 6954   回复: 1
Netro Whisperer
Fabrice GOUFFRAN
更新时间 2022-04-28 12:29:53 UTC
I am unable to have my new whisperer working. It doesn’t light on even after half a day under the sun.
浏览: 8975   回复: 1
