Duane Smith
更新时间 2022-02-16 21:58:22 UTC
Good Afternoon Everyone,
Duane
浏览: 8179   回复: 1
Netro Sprite 6 no enciende la bomba
Vanina Lesko
更新时间 2022-02-20 12:24:48 UTC
Hicimos la instalación tal como figura el manual pero ni las electroválvulas ni la bomba de agua enciende cuando programó el riego. La app dice q está regando pero no funciona el riego.
浏览: 9258   回复: 2
future user of your device
ELBOUHSSAINI larbi
更新时间 2022-02-24 22:49:40 UTC
currently I have a rain bird 4 station device without wifi which gives me satisfaction but unfortunately without wifi zpres research on the internet your device interests me and I want to have some explanation
 - does the device work and trigger the irrigation program in case of wifi failure
 -Does the device back up program data in the event of a power outage?
 - does the humidity sensor come with the device i no where can i buy it
 thank you for answering my questions
浏览: 7823   回复: 1
Netro Spark
ELBOUHSSAINI larbi
更新时间 2022-02-25 12:22:22 UTC
浏览: 6336   回复: 1
Meteo
Rob Rossi
更新时间 2022-02-25 13:46:37 UTC
How can i solve?
Thanks very much
浏览: 6704   回复: 2
Wifi issues
Anthony Bowersox
更新时间 2022-02-27 22:11:24 UTC
浏览: 6295   回复: 1
Interface
John Degolyer
更新时间 2022-03-02 05:58:45 UTC
浏览: 8888   回复: 2
Gabriele Cofano
更新时间 2022-03-02 12:45:59 UTC
浏览: 8010   回复: 1
Whisper sensor
Anthony Bowersox
更新时间 2022-03-11 00:01:41 UTC
浏览: 6296   回复: 1
Netro pixie in standby
mbhi
更新时间 2022-03-12 10:44:15 UTC
浏览: 8060   回复: 1
Problem Sprite 6
Davide Benfenati
更新时间 2022-03-12 16:41:44 UTC
浏览: 7955   回复: 1
It says it sleeping
Judith Soth
更新时间 2022-03-12 22:25:49 UTC
浏览: 6809   回复: 1
Flow rate
Sander Z
更新时间 2022-03-14 12:34:05 UTC
浏览: 7997   回复: 1
Justin Kirk
更新时间 2022-03-16 14:24:09 UTC
浏览: 6491   回复: 2
Whisperers not sending data
更新时间 2022-03-18 12:17:29 UTC
浏览: 7259   回复: 1
Mark Killeen
更新时间 2022-03-18 21:39:54 UTC
浏览: 7058   回复: 1
Joe Baxter
更新时间 2022-03-18 22:42:37 UTC
浏览: 6983   回复: 3
Hitesh
更新时间 2022-03-20 00:34:11 UTC
浏览: 7183   回复: 2
Lost connection
Simone Teressi
更新时间 2022-03-20 16:49:15 UTC
Router signal is 100%
浏览: 8301   回复: 1
Shkelqim Ismet Hoxha
更新时间 2022-03-21 14:10:28 UTC
浏览: 7066   回复: 1
