Incorrect rainfall accumulation
rwflower
更新时间 2022-04-29 16:35:33 UTC
I live in Katy Texas and have been using the Netro water controller in smart mode for over 2 years with no problems.  We received at least 1.5in of rain on the April 25, so I was dismayed to find my sprinkler system watering my yard on the morning of the 26th.  The rain graph in the app is showing 0.03in for the 25th and is clearly wrong.  I have tried changing to all the different weather providers, but the total rain accumulation doesn't change.  The frontal system that caused the rain passed over the entire area, so this is not a situation of local shower only affecting a localized area.
浏览: 8653   回复: 2
Location outside USA
Eduardo Prieto
更新时间 2022-04-30 09:45:16 UTC
I live in Spain and ubication selector do not let me specify my correcto location. I assume It is requieres to provide the Meteorological service the place where to predict weather, so if location is incorrect, the weather too and the watering planning is not optimized properly.
Please work It out un Next app releases.
浏览: 8194   回复: 1
Dhar Sawh
更新时间 2022-05-01 13:26:09 UTC
Dhar
浏览: 6965   回复: 2
Pixie shows "communicating" and timer counting down but valve not open?
Douglas Ely
更新时间 2022-05-01 15:54:22 UTC
When trying to use the Pixie to manually water the garden, I go to the Netro app and select the pixie. It shows "sleeping", 99%charged. I then select "manual run" and set a time. The app then grays out and says "communicating" as the timer begins counting down my preset manual time but the valve stays closed. Why? When does it open?
浏览: 9460   回复: 3
Wifi reconnect issue
Giacomo
更新时间 2022-05-03 21:04:03 UTC
Hi All,
I'm a satisfied Italian customer of Netro Sprite 12 zones since 2019!
Recently I set my router to shutdown the wifi during the night, the Netro sprite it's the only one device that don't automatically reconnect when wifi come up in the morning, the white LED still blinking. To reconnect at the network, I need to phisically shutdown and power on the Sprite.
Is there a "trick" or an update to cover this issue? HW Version: 1.2 , Firmware Version 1.1.3
Thanks in advance.
Giacomo
浏览: 10258   回复: 5
Rain stop
Javier Baruque
更新时间 2022-05-03 14:52:20 UTC
浏览: 7970   回复: 1
water valve does not work
Paolo Raviolo
更新时间 2022-05-03 15:55:47 UTC
I set up the pixie timer, everithing seems ok but the valve does not opens, nor with program nor in manual mode, no water at all.
can you help me?
浏览: 8197   回复: 1
No moisture reading
dsingelyn
更新时间 2022-05-04 17:59:14 UTC
Suggestions?
浏览: 8831   回复: 3
Smart watering -how do I know
John Kot
更新时间 2022-05-05 21:44:57 UTC
If I have smart watering enabled does it activate sprinklers when it (sprite) determines a need?  If so how do I prevent that when I happen to be mowing the lawn?
浏览: 8381   回复: 1
mspenner3
更新时间 2022-05-06 00:09:34 UTC
浏览: 6600   回复: 1
Unable to save programs
Arnaud
更新时间 2022-05-08 13:27:21 UTC
Hello, when I program the repeated watering schedules, it does not appear in the calendar and nothing happens.
浏览: 6262   回复: 1
How do I test the sprinkler system
themaguires4727
更新时间 2022-05-08 22:44:59 UTC
The instructions on page 12 of the Netro sprite quick start guide says I can use the ‘remote control’ feature to on the Netro app to turn on and off the sprinklers. I can’t find a ‘remote control’ setting on this app.
This entire system is making me feel like an idiot. Please help.
浏览: 6315   回复: 1
Jonas Lindholm
更新时间 2022-05-09 02:22:56 UTC
浏览: 6523   回复: 1
Watering out of schedule time
Luca Cerini
更新时间 2022-05-09 09:14:09 UTC
Luca
浏览: 7958   回复: 1
Rain Strategy
Luca Cerini
更新时间 2022-05-09 09:24:20 UTC
Luca
浏览: 7931   回复: 1
SoCal Mandatory "Once a Week" Watering
Jonathan B.
更新时间 2022-05-09 16:14:12 UTC
I've been given a notice that my county will require "Once weekly" watering beginning in June 2022. Will my Netro Sprite automatically adhere to this schedule or do I have to set it up myself?
浏览: 8111   回复: 3
Broken part
Jeremie Coderre
更新时间 2022-05-10 02:52:42 UTC
Hi there!
Thanks in advance!
浏览: 8164   回复: 1
Rain Delay Setting
Nicholas Lydakis
更新时间 2022-05-10 17:37:16 UTC
浏览: 7432   回复: 1
pollomito
更新时间 2022-05-10 19:31:57 UTC
Netro spark can be configured and used as timer if no wifi access point are available?
It is possible to use it by connecting directly mobile phone with spark without additional devices?
Thx
浏览: 8940   回复: 2
instruction manual of the Netro Sprinkler
Rolando Silvano
更新时间 2022-05-11 18:59:03 UTC
Where can I find the instruction manual of the Netro Sprinkler Smart Controller?
thank you
Silvano
浏览: 8202   回复: 1
