Server offline
Mirko Paganelli
更新时间 2021-03-30 16:15:01 UTC
浏览: 7398   回复: 1
Kevin Westling
更新时间 2021-03-28 06:40:48 UTC
浏览: 7239   回复: 1
When will be Netro Smart available in Europe?
Raúl Vázquez-Noguerol Méndez
更新时间 2021-03-20 20:38:05 UTC
I’d like to know if Netro Spark will be available in Europe.
浏览: 6932   回复: 1
What does the app show for whisperer?
Growbro
更新时间 2021-03-17 20:54:48 UTC
I am trying to figure out what the graph shows for the week. It seems like the app shows the average light for the day. Moisture present at midnight each day. And average temperature each day. Is this correct? Or is it maximum temperature for the day?
It would be nice if I could have the graph could show more than just one reading per day. It would also be nice if you could go back and see the more detailed chart for a full day after it has passed. As it is now I can only see the one data point for days that are past.
Finally for the individual days it is a bit annoying switching between am and pm. I wish there was just a graph for each day that looked like the graph for the week/month except that there was a data point for every hour. Definitely more annoying and less useful to have am and pm separate and not be able to see the changes like you can with the graph.
浏览: 7019   回复: 1
Foreca as weather provider
Fran Roman
更新时间 2021-03-09 21:21:35 UTC
Please add Foreca as weather provider! In Europe is much better than the available options on the app. Metro group is also a good option for your European customers like me.
浏览: 7040   回复: 1
Zone says Loading
deleted_20260815225307_Gale
更新时间 2021-02-24 14:03:11 UTC
After the numerous power outages in Dallas last week, my sprinklers attempted to run this morning.   At its scheduled time, the zone shows "loading" but - no water.   ???
浏览: 6887   回复: 1
Smart Watering Algorithm
更新时间 2021-02-09 13:52:56 UTC
浏览: 7757   回复: 1
Date Format
Brian Keenan
更新时间 2021-01-29 09:00:07 UTC
浏览: 6942   回复: 1
Geron R
更新时间 2021-01-19 23:06:52 UTC
Please advise
浏览: 7446   回复: 1
Metro France cloud down?
Julian Hansen
更新时间 2020-12-29 01:07:40 UTC
浏览: 7703   回复: 1
Roman Stanek
更新时间 2020-12-27 18:34:40 UTC
浏览: 6920   回复: 1
App stuck on Idle
Pam Manwaring
更新时间 2020-11-18 02:21:16 UTC
浏览: 7021   回复: 1
Stan Balafas
更新时间 2020-11-16 17:52:28 UTC
Thank ypu
浏览: 7109   回复: 1
Add zones manually in queue
Haris Eliades
更新时间 2020-11-03 04:04:49 UTC
浏览: 7450   回复: 1
"Next in" shows "--"
Luis Aguilar
更新时间 2020-10-14 18:45:01 UTC
浏览: 7171   回复: 1
Questions about Netro app
Luis Aguilar
更新时间 2020-10-11 17:47:55 UTC
浏览: 7315   回复: 1
Simone Nolletti
更新时间 2020-10-11 11:46:06 UTC
Buonasera,
浏览: 7850   回复: 1
Switch Off automatically
Carlos Jimenez
更新时间 2020-10-09 20:18:31 UTC
I found two cases,
浏览: 7149   回复: 1
Atif Khan
更新时间 2020-10-01 14:21:57 UTC
浏览: 7115   回复: 1
Simple on/off
gmcg1984
更新时间 2020-09-17 01:54:35 UTC
浏览: 7138   回复: 1
