Richtiger niederschlag
Gregor Schuller
更新时间 2021-06-21 09:41:39 UTC
Hallo,
Zurzeit ist nur 1 mm möglich
浏览: 7185   回复: 1
Network error
Al Piscopo
更新时间 2021-06-17 10:27:03 UTC
浏览: 6631   回复: 1
Watering adjustment settings
Lyndon Whyatt
更新时间 2021-06-15 16:55:38 UTC
浏览: 7458   回复: 2
Text overlap in App
Kevin Westling
更新时间 2021-06-12 14:46:02 UTC
浏览: 7191   回复: 1
Looking for Beta testers
更新时间 2021-06-11 06:11:28 UTC
Dear all Netro customers,
The long waited new version (3.0.0) of the Netro app is on the horizon. The major improvements of this version are
1. faster in loading data
2. new manual run interface
3. new home view design
4. more languages supported
We sincerely invite you to join the Beta testing program. Please email to support@netrohome.com or leave a message below if you would like to try the new app. Any feedback would be greatly appreciated !
Netro App Team
浏览: 31998   评论: 60
更新时间 2021-06-10 05:30:31 UTC
浏览: 7334   回复: 1
Network Error With Code: 3404
Ian Meyer
更新时间 2021-06-08 16:16:25 UTC
浏览: 7408   回复: 1
Pause a location\device
Jon Storch
更新时间 2021-06-06 23:08:20 UTC
-Jon Storch
浏览: 7317   回复: 1
Manual Watering
Kevin Westling
更新时间 2021-06-04 00:42:16 UTC
浏览: 7232   回复: 1
sal.jamil@me.com
更新时间 2021-06-02 12:11:24 UTC
浏览: 6935   回复: 1
60 minute limit
C S
更新时间 2021-06-01 21:33:39 UTC
浏览: 6829   回复: 1
Yuriy Andamasov
更新时间 2021-05-31 19:44:41 UTC
Thanks in advance.
浏览: 7085   回复: 1
Pedro Abad
更新时间 2021-05-30 08:33:28 UTC
Thank you all!
浏览: 7390   回复: 2
Douglas Peale
更新时间 2021-05-27 22:32:59 UTC
浏览: 7279   回复: 1
banaszar
更新时间 2021-05-25 17:23:58 UTC
浏览: 6870   回复: 2
Brad Grizzly
更新时间 2021-05-23 03:42:20 UTC
浏览: 6772   回复: 1
bad wireless?
amagalla
更新时间 2021-05-19 16:50:44 UTC
Tony
浏览: 7330   回复: 1
amagalla
更新时间 2021-05-19 16:45:52 UTC
Edit:
The app on my tablet shows:
Server Status:    OK
Response time:  0.3 s
浏览: 8166   回复: 2
Whisperer connexion
更新时间 2021-05-19 14:52:55 UTC
浏览: 8241   回复: 2
Turning off wayer
更新时间 2021-05-16 21:29:12 UTC
浏览: 7764   回复: 2
