Seed watering
Adrian Azzopardi
更新时间 2021-05-16 10:18:05 UTC
浏览: 7150   回复: 1
Update Firmware
Tognaz
更新时间 2021-05-10 12:35:23 UTC
Hello everyone,
Checking with the Netro app, I see that my Sprite has firmware version 2.2.0, while I think I read in the forum that there is version 2.5.3.
How can I force the update?
浏览: 7138   回复: 1
Latest software update
Sheryl New
更新时间 2021-05-02 21:59:11 UTC
Is 2.5.3 the latest Netro Sprite software version?
浏览: 9398   回复: 3
Internet connection
Sheryl New
更新时间 2021-05-02 21:57:36 UTC
My Netro Sprite constantly drops offline. Help, please.
浏览: 7294   回复: 2
soil fertility
更新时间 2021-05-02 15:17:33 UTC
Why the Whisperer doesn’t measure the soil fertility?
浏览: 7390   回复: 1
I live in the US but want my temperature in celsius
smartplastic
更新时间 2021-04-27 00:19:53 UTC
Hi I’m and Aussie living in the US and although I am happy to use pounds and feet etc Fahrenheit is just a ridiculous pile of crap that is used nowhere else in the world.
How can I get the temperature display in my Netro app to show in Celsius?
浏览: 6887   回复: 1
Netro app discover tab
Zee D
更新时间 2021-04-25 20:52:09 UTC
浏览: 6878   回复: 1
LAWN
更新时间 2021-04-23 23:08:09 UTC
Set up wifi
Neti URC - 87B (ok saved)
home netwok connected.
浏览: 7062   回复: 1
Email address
Troy pascoe st
更新时间 2021-04-19 11:01:30 UTC
浏览: 6966   回复: 1
dougbrandes
更新时间 2021-04-19 10:06:30 UTC
浏览: 7000   回复: 1
Multiple Pixies?
J Forrest
更新时间 2021-04-17 03:33:18 UTC
浏览: 7013   回复: 1
How to delete a device
Carles
更新时间 2021-04-16 12:33:31 UTC
浏览: 7341   回复: 1
Time zone not supported
Havre de Grace
更新时间 2021-04-15 08:11:30 UTC
I keep getting this error when I try to put my address in Jersey, Channel Islands.
浏览: 6750   回复: 1
Fabio Pellizzoni
更新时间 2021-04-13 20:10:43 UTC
Do you have any idea why ?
浏览: 7138   回复: 1
Imran Ali
更新时间 2021-04-12 22:54:05 UTC
Imran Ali
浏览: 7387   回复: 1
Scott Gustafson
更新时间 2021-04-10 16:04:18 UTC
Scott
浏览: 7737   回复: 1
Moisture Level
Des Mullin
更新时间 2021-04-09 23:48:09 UTC
浏览: 7557   回复: 1
David Farries
更新时间 2021-04-07 02:16:14 UTC
浏览: 7176   回复: 1
jjmengibar
更新时间 2021-04-05 18:16:46 UTC
How can I reset any zone
浏览: 7675   回复: 1
What do the icons mean?
Jim Stichbury
更新时间 2021-03-31 06:55:06 UTC
浏览: 7059   回复: 1
