Restrictions do not include minute limits
Cheryl Michael
更新时间 2022-05-17 03:03:27 UTC
I cannot find a way to reduce the minutes each station is watered. All stations on Eco boost. And some water almost an hour total (in 3 sessions) on allowed watering days. Our local So Cal restrictions are 10 minutes per station! How do I restrict  this?
浏览: 6364   回复: 1
Weather .
Gianluca De Virgilio
更新时间 2022-05-15 17:39:09 UTC
Good afternoon. The Weather forecast avvailable are absolutelly not real. What can I do?
Could you help me to con figure weather underground?
浏览: 6921   回复: 2
Offline since a couple of days
Daniel Torres
更新时间 2022-05-15 10:01:39 UTC
Since a couple of days my Netro is offline. I have connected to my Netro to add the wifi password again and rebooted the router 3 times but still offline.
浏览: 6665   回复: 1
Good evening It but impossible to connect me netro tells me to make sure that the correct WIFI password is entered ... I have been trying to appear for 4 hours
GERMONT Alain
更新时间 2022-05-13 23:02:49 UTC
Good evening
浏览: 7007   回复: 3
How do I set on/off times?
Rikki Swin
更新时间 2022-05-13 17:37:43 UTC
How do I program the on/off time on the new software? I need to have gaps between zones for pressure to rebuild. The new software is not intuitive!!!
浏览: 6213   回复: 1
stelio
更新时间 2022-05-13 00:33:14 UTC
Netro working fine last summer , I can seem
To get it to stay online . I reset the Netro and it work fine for the first 10 min … then it logs off and leave on zone open . I don’t know what to do ,To keep it online ?
浏览: 6716   回复: 1
Netro not connecting
hawkshah
更新时间 2022-05-12 02:02:39 UTC
I have switched internet providers and now Netro won’t connect to att modem.  I have run through setup many times
浏览: 6209   回复: 1
SoCal Mandatory "Once a Week" Watering
Jonathan B.
更新时间 2022-05-09 16:14:12 UTC
I've been given a notice that my county will require "Once weekly" watering beginning in June 2022. Will my Netro Sprite automatically adhere to this schedule or do I have to set it up myself?
浏览: 7986   回复: 3
How do I test the sprinkler system
themaguires4727
更新时间 2022-05-08 22:44:59 UTC
The instructions on page 12 of the Netro sprite quick start guide says I can use the ‘remote control’ feature to on the Netro app to turn on and off the sprinklers. I can’t find a ‘remote control’ setting on this app.
This entire system is making me feel like an idiot. Please help.
浏览: 6191   回复: 1
Unable to save programs
Arnaud
更新时间 2022-05-08 13:27:21 UTC
Hello, when I program the repeated watering schedules, it does not appear in the calendar and nothing happens.
浏览: 6152   回复: 1
Activity not showing on ap
Mark Killeen
更新时间 2022-04-27 15:21:38 UTC
浏览: 6997   回复: 1
Brian Brun
更新时间 2022-04-26 04:23:12 UTC
浏览: 6897   回复: 1
Blinking light on my Netro
RMeador
更新时间 2022-04-21 01:20:07 UTC
浏览: 6193   回复: 1
Netro lose wifi connection
Rob Rossi
更新时间 2022-04-19 09:22:12 UTC
If I restart the router,
how can it be solved?
浏览: 6551   回复: 1
Alessandro Malaguti
更新时间 2022-04-18 10:04:06 UTC
I attach mp4 link
浏览: 6213   回复: 1
Mike Ahlmann
更新时间 2022-04-06 18:41:13 UTC
浏览: 7211   回复: 1
Maureen Horan
更新时间 2022-04-05 17:22:11 UTC
How do I add a zone
浏览: 6487   回复: 1
Addind new pixie
jesusvenegas
更新时间 2022-03-29 13:10:04 UTC
浏览: 6145   回复: 1
Smart Zone over watering
Scott Flanigan
更新时间 2022-03-26 11:21:58 UTC
浏览: 7044   回复: 1
Werner Baier
更新时间 2022-03-26 09:58:21 UTC
浏览: 6826   回复: 1
