Sprite 6 will not connect
Robert Christel
更新时间 2022-11-19 18:45:59 UTC
Bob
浏览: 6860   回复: 1
Manual Mode not working
Gary C
更新时间 2022-11-08 23:30:48 UTC
浏览: 6849   回复: 2
Netro light
Alessandro Zannini
更新时间 2022-11-05 20:16:40 UTC
浏览: 7102   回复: 1
Percentage Adjustment
jeremyagrelius@gmail.com
更新时间 2022-10-29 18:31:12 UTC
浏览: 6776   回复: 1
Daniel Gajardo
更新时间 2022-10-27 01:22:57 UTC
浏览: 7337   回复: 1
Cutrone
更新时间 2022-10-25 17:06:24 UTC
Hello all!
浏览: 8062   回复: 2
更新时间 2022-10-20 14:57:19 UTC
Thanks for your advice
浏览: 7222   回复: 1
Water pressure
Omer Zadikevitch
更新时间 2022-10-18 18:15:38 UTC
浏览: 6916   回复: 1
Weather station
更新时间 2022-10-14 02:07:16 UTC
浏览: 7706   回复: 1
No connection to WiFi.
Gianluca De Virgilio
更新时间 2022-10-02 21:48:54 UTC
Good afternoon.
浏览: 8144   回复: 2
Discover and weather accuracy
Geron R
更新时间 2022-10-01 12:38:37 UTC
浏览: 7248   回复: 1
Veronica Slaughter
更新时间 2022-10-01 05:11:02 UTC
Any insight is so welcome!
浏览: 7069   回复: 1
Rick Miller
更新时间 2022-09-29 23:49:53 UTC
浏览: 6959   回复: 1
Rosario Russo
更新时间 2022-09-27 11:06:57 UTC
浏览: 6930   回复: 1
Ananth
更新时间 2022-09-21 12:25:49 UTC
 How do i change this?
lot of water being wasted.
Ananth Bandla
浏览: 8180   回复: 2
quick stop every watering
Lee Hill
更新时间 2022-09-11 20:34:04 UTC
浏览: 7266   回复: 1
更新时间 2022-09-07 05:47:06 UTC
May you check it?
浏览: 7636   回复: 1
更新时间 2022-09-05 21:41:34 UTC
KVACHEST132
浏览: 7581   回复: 1
Random sprinklers turn on
Brian Strickler
更新时间 2022-09-01 12:33:12 UTC
浏览: 7364   回复: 2
Program
Bob Neal
更新时间 2022-08-31 17:11:55 UTC
浏览: 6860   回复: 1
