How do I save my password
Ruth Wengert
更新时间 2026-06-09 16:33:16 UTC
I doubt if someone’s gonna break in and change my sprinkler time how in the hell do I save my password to this thing? I don’t wanna have to remember to put it in every time I want to change my sprinklers.
浏览: 2477   回复: 1
Change Wi-Fi connection
Ruth Wengert
更新时间 2026-05-20 03:18:14 UTC
I have changed the name of my Wi-Fi. I need to change my Wi-Fi connection to its new name
浏览: 2439   回复: 1
Changing WiFi Network post original installation
deleted_20260518221841_george
更新时间 2026-05-18 14:03:27 UTC
Hi- been using your sprinkler controller for several years and have recently added a new WiFi network.
I'm following the instructions how to switch the Netro controller to a new WiFi network. After resetting the controller, it change my iphone WiFi network over to Netro-XXX (which tells me I have no internet access).
When I return to the Netro app and click 'Next', it just keeps instructing me to connect to Netro-XXX first.
The Netro controller continues to blink despite unplugging it so stuck in limbo now.
浏览: 2499   回复: 2
Why would it show rain on the Home Screen when there is none in the forecast
Michael Harrington
更新时间 2026-05-16 01:39:35 UTC
浏览: 2517   回复: 1
When Zone 11 is programmed to run but zone 4 runs instead.
Mike
更新时间 2026-04-21 18:10:56 UTC
Zone 4 correctly runs when zone 4 is activated
浏览: 3202   回复: 1
Any way for user to open and replace battery in Whisperer 2?
更新时间 2026-04-09 02:24:02 UTC
Any way for end user to open and replace battery on a whisperer 2?  It is out of warranty.
浏览: 3363   回复: 1
Peter OBRIEN
更新时间 2026-03-27 00:55:46 UTC
Samsung S25 - unable to pair own WIFI after connection to Netro
浏览: 3771   评论: 1
Pixie solar panel
Noam Leshem
更新时间 2026-03-23 14:31:41 UTC
Just i thought. My pixie is connected to a tap that is shaded most of the day. It would be great if the solar panel was removable so it can be placed in a better place with a wire to the pixie.
浏览: 3634   评论: 2
Pixie se desconecta
Lino
更新时间 2026-03-22 19:30:16 UTC
Por qué se desconecta después de unos minutos mi unidad Pixie si tiene batería?
浏览: 3411   回复: 1
Drip
Tim P
更新时间 2026-03-22 18:23:10 UTC
All the zones work except I do not have any water coming out of the drip heads
浏览: 3296   回复: 1
Drip
Tim P
更新时间 2026-03-22 18:03:51 UTC
浏览: 3338   回复: 1
Drip
Tim P
更新时间 2026-03-22 18:03:43 UTC
浏览: 3311   回复: 1
New whisperer
更新时间 2026-03-03 08:20:29 UTC
Bought a new whisperer as an old one is no longer working.
REMARK : WHILE I LIVE IN A TEMPERATE AREA NONE OF MY WHISPERERS LASTS MORE THAN 26 MONTHS WHICH IS SURPRISING AS IT IS NOT SUPPOSED TO BE A CONSUMABLE.
Clicked as required first blinking blue light then blinking white light.
Went to sensors and see the dead old one, the working one but do not see the newly bought one.
Do not see either a + sign to add a new one.
What should I do ?
浏览: 3602   回复: 1
Tuan Phan
更新时间 2026-01-25 18:28:34 UTC
浏览: 3495   回复: 1
Eric Jonsson
更新时间 2026-01-08 12:02:58 UTC
浏览: 3888   回复: 1
API broken?
Tortfeaser
更新时间 2025-11-21 04:58:13 UTC
Hi, I can get my Netro controller info using:
curl -v https://api.netrohome.com/npa/v2/info.json?key=MYAPIKEY
(where MYAPIKEY is a key from the user account page)
but when I try to update soil moisture data with:
curl -X POST -H "Accept: application/json" -H 'Content-Type:application/json' -d '{"key":"MYAPIKEY","moisture":100}' "https://api.netrohome.com/npa/v2/set_moisture.json"
I get an error about an invalid key:
{"status":"ERROR","meta":{"time":"2025-11-21T04:54:56","tid":"1763700896_KpmY","version":"2.0","token_limit":0,"token_remaining":0,"last_active":"2025-11-21T04:54:56","token_reset":"2025-11-22T00:00:00"},"errors":[{"code":1,"message":"Invalid key: ","params":{}}]}
What's going on?
浏览: 16263   回复: 1
Zone flexibility
Mike R
更新时间 2025-10-29 01:20:50 UTC
I have a hill that was terraced and replanted. I was told to run the circuit twice a day for 15 minutes for a month. Drip lines. Seems like my system doesn’t have that flexibility. Am i correct?
浏览: 4293   回复: 1
App crash
Nick
更新时间 2025-10-12 20:41:50 UTC
The app crashea when I click on a zone on Google pixel 8a. I had to configure them with another phone. Already tried to reinstall the app and clear cache
浏览: 4598   回复: 1
L irrigazione non parte
Marco Michelini
更新时间 2025-10-11 15:55:45 UTC
Hi, dopo aver collegato tutto, ho provato a fare un test manuale ma non parte l irrigazione.
Sapete aiutarmi?
浏览: 4383   回复: 1
Program change Day
Tiziano Pacella
更新时间 2025-09-17 19:04:30 UTC
Someone can help me?I need change the day for one program exists...what is the procedure? Thak you
浏览: 5526   回复: 1
