更新时间 2019-06-05 01:59:12 UTC
To the Netro community:
浏览: 386946   评论: 24
Piti Germany
更新时间 2019-06-03 22:49:27 UTC
Many thanks in advance
Peter
浏览: 10341   回复: 1
Wont recognize network which has an apostrophe in the name?
Douglas Ely
更新时间 2019-06-03 15:27:39 UTC
My customer has a network name that contains an apostrophe. Larry Arch's Wifi. He uses an AirPort Extreme router and two AirPort Extreme range extenders. They have many household devices connected to this network and all of their service contractors use it too. Is there a workaround? They will not be able to use Netro products if there isn't.
浏览: 10281   回复: 1
Netro offline and not watering
Mark
更新时间 2019-05-28 22:23:43 UTC
netro shows offline.  The app says zones are watering but no watering is occurring.   Plants are dying.
Retro device has a white light.
How do I fix this?
浏览: 9232   回复: 0
Zones
José Miguel Salcedo
更新时间 2019-05-28 20:03:07 UTC
Why  can't I water two zones at the same time
浏览: 9818   回复: 1
Netro off line
更新时间 2019-05-25 02:59:21 UTC
浏览: 10258   回复: 1
Joshua Berk
更新时间 2019-05-23 18:39:21 UTC
浏览: 10086   回复: 1
Manual mode fail to shut off
更新时间 2019-05-16 02:05:13 UTC
浏览: 10209   回复: 1
Problemi con Google home
Max Point
更新时间 2019-05-12 08:36:40 UTC
Massimo
浏览: 9753   回复: 1
Answers?
Howard Blankenship
更新时间 2019-04-24 14:46:54 UTC
浏览: 9225   回复: 1
Smart home integration
Matt Griste
更新时间 2019-03-29 22:29:57 UTC
浏览: 10202   回复: 2
MAC address
Lee Hill
更新时间 2019-03-29 15:45:44 UTC
浏览: 10080   回复: 1
Not able to water
更新时间 2019-03-27 13:18:49 UTC
浏览: 10409   回复: 1
Service
Matt Lasser
更新时间 2018-10-31 16:01:30 UTC
浏览: 10151   回复: 1
George Zraick
更新时间 2018-10-27 20:05:15 UTC
浏览: 9872   回复: 1
Moberley
moberleyj@verizon.net
更新时间 2018-10-17 16:59:29 UTC
浏览: 10355   回复: 1
connecting to wifi..
Phani Gade
更新时间 2018-10-15 17:20:42 UTC
浏览: 9481   回复: 0
Alexa skill with multiple Netro controllers?
James Nyazai
更新时间 2018-08-29 21:13:54 UTC
I have 2 Netro controllers named Front Yard and Back Yard. Alexa can water the Back Yard just fine by specifying a zone and a time to water for. But how do I switch controllers so Alexa will water zones on the Front Yard controller?
浏览: 10688   回复: 0
Reset moisture level
Geoffrey Maslin
更新时间 2018-08-22 23:07:11 UTC
Is there a way to reset the moisture level for a zone. It is currently showing 100% but soil is dry.
浏览: 10813   回复: 1
Offline alert
Alex R
更新时间 2018-08-05 19:29:29 UTC
Is there a way to get the Netro system to alert me if the system goes “offline” . I have had to instantes where the system was off line and my plants almost died
浏览: 12264   回复: 6
