Whisperer Changing Colors
Patrick
更新时间 2020-05-06 02:32:37 UTC
My Netro Whisperer sensor LED changed colors from blue to red on its own.  Is this normal?
浏览: 7567   回复: 1
Sprite app says its watering but it is not
Jen Morgan
更新时间 2020-05-03 18:02:31 UTC
It has been working for 3 weeks, but now it does not.
I have checked all 7 zones. No wiring issues. Has proper voltage.
It just won't come on. How do I get it to work again. This is a new unit. Sprinklers are all fine and had a tune up when the Sprite was installed.
I have unplugged it and plugged it back in. I need help soon, I have new sod and many new plants in my yard and gardens.
浏览: 7674   回复: 1
Sprinklers don’t work
Richard Mundy
更新时间 2020-05-02 18:59:26 UTC
Please help
浏览: 8141   回复: 1
Carlo Monico
更新时间 2020-04-26 06:59:36 UTC
Grazie.
浏览: 7447   回复: 1
Plant Sensor
Ntenaive
更新时间 2020-04-25 21:56:51 UTC
浏览: 8222   回复: 2
Gian Piero Pepino
更新时间 2020-04-25 09:23:06 UTC
Gian Piero
浏览: 7596   回复: 1
Best sync option?
jbart65
更新时间 2020-04-22 02:56:17 UTC
浏览: 7798   回复: 1
google home not connected
maxtrash
更新时间 2020-04-21 23:01:57 UTC
what could be going on?
浏览: 7534   回复: 2
Keep Connected option
jbart65
更新时间 2020-04-17 17:38:10 UTC
The particulars:
浏览: 7787   回复: 1
Which Alexa app?
jbart65
更新时间 2020-04-16 20:00:55 UTC
Jeffry
浏览: 7918   回复: 1
Netro app on google home
Danilo
更新时间 2020-04-11 10:07:58 UTC
Thanks for your support.
浏览: 7680   回复: 1
Settings
Massimo Povolo
更新时间 2020-04-07 06:31:48 UTC
浏览: 8741   回复: 5
Home Assistant integration
Casey S
更新时间 2020-04-05 19:46:53 UTC
浏览: 8408   回复: 2
duerson
更新时间 2020-03-27 20:59:20 UTC
浏览: 7991   回复: 1
Delivering term please
yodiego
更新时间 2020-03-14 18:08:21 UTC
浏览: 7446   回复: 1
alexa & pixie
stefano banfi gaslini
更新时间 2020-03-11 14:30:37 UTC
hi,
TNKS
best regards
stefano
浏览: 7790   回复: 1
更新时间 2020-02-28 07:49:20 UTC
浏览: 12252   评论: 3
Changing ownership of home
Dario Sindicich
更新时间 2020-02-14 01:48:40 UTC
浏览: 9427   回复: 2
Robert Bayes
更新时间 2020-02-07 03:39:19 UTC
浏览: 7332   回复: 1
Introducing the Referral Program
更新时间 2019-12-10 03:02:22 UTC
To the Netro community:
We are pleased to launch the Netro Referral Program. You can earn reward points when your friends become Netro customers!
1.Invite your friends to join Netro using your unique link
2.Your friends get a discount or reward points
Your friends enjoy 10% off their first orders or $10 credits toward their first subscriptions.
3.Get your reward points and repeat to earn more
You will earn reward points* equivalent in value to the discounts or credits given to your friends.
*Reward points: for every US dollar your friends spend on their first orders you will earn 10 points ($0.1). You will earn 1000 points ($10) for every friend who chooses to subscribe. There are 3 ways to redeem the reward points:
1. Use the reward points to purchase Netro products at netrohome.com (100 points = 1 US dollar)
2. Use the reward points to pay for your subscription fee at netrohome.com (100 points = 1 US dollar)
3. Withdraw the reward points to your PayPal account (200 points = 1 US dollar)
Your reward points will never expire.
You can check more info about Netro's Referral Program here https://netrohome.com/shop/refer
浏览: 9249   回复: 2
