Rainbird esp me series
Magnus Swenson
更新时间 2025-09-15 14:38:33 UTC
Can I use the Netro Spark 16 if I use the Rainbird ESP Me? I have 15 active zones.
浏览: 5826   回复: 1
Centralina non funziona
gsciurba
更新时间 2025-09-09 19:23:32 UTC
Buongiorno,
  • la tensione in uscita è sempre di circa 11 V AC su tutte le uscite;
  • la centralina è stata utilizzata pochissimo, solo con le zone master e 1–2;
  • non sono presenti segni visibili di bruciatura o danni hardware.
Grazie per l’attenzione.
Cordiali saluti,
Giuseppe Sciurba
浏览: 6310   回复: 1
Netro spark no work
Fernando Bravo Calatayud
更新时间 2025-09-04 08:25:22 UTC
I've had a Netro Spark 8 working without any problems since last year, but a few days ago it disconnected from the Wi-Fi and stopped working. I tried the reset button as indicated in the instructions, but there's no way to reconnect it. What else can I do? Thank you very much
浏览: 6762   回复: 1
更新时间 2025-08-24 22:55:28 UTC
浏览: 7273   回复: 1
Interoperability with Alexa, Homey, any other smart home platform?
arnaud@brucy.org
更新时间 2025-08-22 19:03:11 UTC
Is there any interoperability/integration existing or planned with home automation/smart home platforms?
Integration with Homey Pro would be great, being able to fetch the watering status for each zone, start a manual watering, or send some external triggers (humidity, rain water tank level, etc.)
Thank you !
Arnaud
浏览: 6962   回复: 2
Pixie valve won’t close
Geoff Miller
更新时间 2025-08-22 16:06:03 UTC
One, and only one ,of my 4 Pixies occasionally sticks in open mode, not closing the valve, watering until I notice it. It won’t shut down from button and I have to turn it off or remove battery to get it to reset. It works for a few days and happens again. It has been working well for about 6 months. Any ideas how to fix this?
浏览: 7003   回复: 2
Spark 16 works only in manual
Davide Riva
更新时间 2025-08-11 21:55:04 UTC
Hello, I’ve installed netro app on my iPhone, followed the procedure to connect the spark 16 and everything is fine, but when I try to activate valves with the app, the led turn white.
If I remove spark 16 from the app, the led turn green and I can only activate valves from the controller,
Any solution?
Davide
浏览: 7093   回复: 2
App reports off-line, controller is on-line and web based app is on-line
Jorge Rodrigues
更新时间 2025-08-08 18:46:45 UTC
I have a strange situation:
- App reports controller as off-line, sometimes it reports on-line for brief periods. It was working fine till three days ago
- Controller has green light
- Web app on the netro site reports on-line and works
- The controller is watering
- The Wifi near the controller is working and I have not changed the password or settings
- I have tried forcing it to change the wifi, I get the bluetooth light and the controller is detected on the app via bluetooth, however it fails after I insert the password for the wifi. This is odd since the device is connected.
I suspect there is a synch issue between the App and your servers. Help would be appreciated.
浏览: 4442   回复: 1
Spark not working – won’t start valves despite all attempts
Stefano
更新时间 2025-07-23 06:55:23 UTC
Hi everyone,
I’ve been using a Netro Spark (8-zone model) for some time, but recently it stopped working properly.
The controller connects to Wi-Fi and appears online in the app, but when I try to start any valve (manually or via schedule), it says “communicating” and nothing happens.
  • Restarted the Spark multiple times
  • Performed a full reset (12 seconds on RST button)
  • Re-added the device in the app
  • Tried to trigger irrigation manually from both the app and the controller
  • Confirmed that the system works when I open the valves manually from the controller
  • Tried different power supplies
  • Connected to a mobile hotspot instead of my home Wi-Fi (same result)
  • Updated the firmware to the latest version (v3.3.0)
  • Purchased a brand new Spark controller and tested it — same exact issue
At this point, it looks like the issue is not hardware or network-related.
Could it be a firmware bug or a server-side problem?
Any help would be greatly appreciated!
Thanks in advance,
Stefano Mauri
浏览: 5597   回复: 3
Issue with Netro Spark
Fabrice GOUFFRAN
更新时间 2025-07-23 06:34:33 UTC
浏览: 5386   回复: 2
Andrew Woods
更新时间 2025-07-22 19:30:55 UTC
浏览: 5153   回复: 1
Stefano
更新时间 2025-07-21 21:17:23 UTC
Hi everyone,
I’ve already tried:
Thanks in advance!
– Stefano
浏览: 7750   回复: 1
Franck FONTANEL
更新时间 2025-07-18 19:49:49 UTC
I don’t know why ?
浏览: 7289   回复: 1
nsutherland
更新时间 2025-07-14 01:33:11 UTC
浏览: 5067   回复: 1
Veronica Slaughter
更新时间 2025-07-03 12:43:45 UTC
浏览: 7306   回复: 0
Valve not opening
更新时间 2025-07-01 05:11:54 UTC
I have a Netto controller 12
浏览: 6915   回复: 1
Font size/ dark mode
更新时间 2025-06-28 04:53:19 UTC
浏览: 7217   回复: 1
Jack De Donato
更新时间 2025-06-26 11:48:52 UTC
Question in subject title
浏览: 6761   回复: 0
Netro Sprite
Cassio
更新时间 2025-06-26 08:43:13 UTC
Thanks for your support!
浏览: 7258   回复: 2
Plant needs
Bob Benny
更新时间 2025-06-19 00:30:05 UTC
Thank you for your help.
浏览: 6450   回复: 1
