Lloyd Walter
更新时间 2022-03-23 08:31:18 UTC
浏览: 13504   评论: 3
更新时间 2022-03-21 21:37:50 UTC
浏览: 8609   回复: 1
Whisper sensor
Anthony Bowersox
更新时间 2022-03-11 00:01:41 UTC
浏览: 6501   回复: 1
Wifi issues
Anthony Bowersox
更新时间 2022-02-27 22:11:24 UTC
浏览: 6496   回复: 1
Netro Spark
ELBOUHSSAINI larbi
更新时间 2022-02-25 12:22:22 UTC
浏览: 6527   回复: 1
Whisper temperature and solar data availability to ITTT
August Divjak
更新时间 2022-02-11 18:31:44 UTC
Whisper temperature and solar data availability to ITTT or another application so I can trigger events on Leviton system.
浏览: 6857   回复: 1
I can’t seem to be able to reschedule my program
cmeital
更新时间 2022-02-07 21:51:50 UTC
浏览: 6455   回复: 1
Marcos De Maria
更新时间 2022-02-07 19:44:16 UTC
Buenas ! No logro que prenda el riego .. si ven en la
Foto tengo una electro válvula roja .. para un lado funciona el llenado de la pileta , para el otro el riego x manguera .. en 0 Que es donde está en la foto debería darle la orden la computadora para que encienda la bomba y empiece a regar q estoy haciendo mal ??
浏览: 7162   回复: 2
Jamie Campbell
更新时间 2022-01-16 22:09:35 UTC
Every time I go to login to the app, it crashes back to the iOS Home Screen. I’m running iOS 15.1.1 on an iPhone mini. I have tried deleting and reinstalling the app several times and the app works until I put my login details in, then it crashes.
浏览: 6858   回复: 2
No wifi connection
lawnguy4
更新时间 2022-01-10 05:16:03 UTC
Just got the Sprite 6 controller and it won't connect to Wi-Fi. I have a mesh wi-fi system and the controller has full bars but it just refuses to connect. I reset it a couple times , I  unplugged and plugged it back in , I tried deleting the app and doing it again and still no luck. I just keep getting an error saying ''Action control parameter missing or value is empty'' no clue what that means. Can anyone give me some advice on what else I can possibly do to make this work.. Thank you.
浏览: 6556   回复: 1
What is the expected format for entering weather underground? weather id?
August Divjak
更新时间 2022-01-07 23:41:01 UTC
For
KFLORLAN660 Id in weather underground app,. The setup continues to state that I should supply a valid I'd code.  I've tried many different ways with no luck.  Can you help here?
浏览: 7361   回复: 1
Master valve issue.
Danny L
更新时间 2021-12-29 04:13:11 UTC
浏览: 7679   回复: 1
Whisper at 0%
Darren Cassar
更新时间 2021-12-27 09:00:28 UTC
浏览: 6696   回复: 1
Nguyễn Vinh
更新时间 2021-12-09 08:29:48 UTC
浏览: 7273   回复: 1
Lawrence Mantin
更新时间 2021-12-05 17:01:06 UTC
浏览: 6677   回复: 1
Vieri Verze
更新时间 2021-11-29 23:09:31 UTC
浏览: 7050   回复: 1
Whisperer failed?
Marlpit
更新时间 2021-11-15 21:27:46 UTC
浏览: 9093   回复: 2
Blowout in the rain
lugo
更新时间 2021-11-12 19:02:41 UTC
浏览: 6484   回复: 1
Erros
Nabil Ben ismail
更新时间 2021-11-10 13:50:29 UTC
Erreur 4847 ? C'est quoi
浏览: 6479   回复: 1
How to do a manual zone start
Jim Smith
更新时间 2021-11-07 00:41:28 UTC
浏览: 7624   回复: 1
