Jcraft200
更新时间 2021-07-18 02:44:57 UTC
I get to set 3 set up wifi
TIA
浏览: 7310   回复: 4
Internet down
更新时间 2021-07-18 11:38:25 UTC
浏览: 8761   回复: 2
Addiel Isaac Moldes
更新时间 2021-07-18 12:42:37 UTC
It was or wasn't included?
浏览: 7231   回复: 1
Default view on startup
Addiel Isaac Moldes
更新时间 2021-07-18 12:45:53 UTC
浏览: 7208   回复: 1
wwhitfill
更新时间 2021-07-18 13:52:07 UTC
浏览: 8328   回复: 2
Barry Litinsky
更新时间 2021-07-18 23:12:56 UTC
浏览: 6603   回复: 1
Pixie and Whisperer
Nick Thoman
更新时间 2021-07-19 17:46:37 UTC
浏览: 7365   回复: 1
Ramón Rivero
更新时间 2021-07-20 08:32:53 UTC
浏览: 7059   回复: 1
Not all zones are executing
Brian Brun
更新时间 2021-07-20 14:19:47 UTC
浏览: 7641   回复: 1
BaiPhillips
更新时间 2021-07-20 20:42:15 UTC
浏览: 7121   回复: 2
New lawn setting
更新时间 2021-07-21 01:54:26 UTC
浏览: 7649   回复: 1
Netro Pixie with Google Home
fauxserious
更新时间 2021-07-21 19:50:41 UTC
What is the issue?
浏览: 7433   回复: 1
Two electro valves activated at same time
Francesc Rodríguez
更新时间 2021-07-21 20:07:01 UTC
Why is not possible two valves operating at the same time if the pump can be operate correctly?
浏览: 8953   回复: 1
Connect to a network
James Yates
更新时间 2021-07-22 21:08:14 UTC
浏览: 6417   回复: 1
Keep Online
bechard
更新时间 2021-07-24 11:09:25 UTC
浏览: 7709   回复: 0
Strange Whisperer Acrtivity
更新时间 2021-07-24 17:00:16 UTC
浏览: 11512   回复: 5
Eric
更新时间 2021-07-25 05:56:52 UTC
浏览: 6535   回复: 1
Installing New Netro-6
Debby Plenert
更新时间 2021-07-25 14:37:04 UTC
I removed an older controller and replicated the wiring when installing the new Netro.  Everything appears to be correct?  However, when watering is activated, the valves will fill up and vibrate or what not with water rushing internally.  But the sprinkler heads don’t pop up and no water comes out.  Any help here would be greatly appreciated.  Thanks!
浏览: 8809   回复: 1
Rain sensor
更新时间 2021-07-26 12:13:34 UTC
浏览: 8959   回复: 1
更新时间 2021-07-26 16:02:28 UTC
浏览: 8962   回复: 2
