whisperer + smartzone
更新时间 2021-06-14 20:59:45 UTC
浏览: 9131   回复: 1
Backup
klzig
更新时间 2021-06-15 14:09:28 UTC
Best I can tell from the cursory technical specs is that for the Sprite the backup for a custom (not smart) watering schedule is in the cloud and for the Spark the backup is stored on-device in nonvolatile memory.  Is this correct?
浏览: 8535   回复: 1
klzig
更新时间 2021-06-15 14:16:19 UTC
浏览: 8255   回复: 1
Watering adjustment settings
Lyndon Whyatt
更新时间 2021-06-15 16:55:38 UTC
浏览: 7583   回复: 2
更新时间 2021-06-16 14:03:50 UTC
浏览: 7706   回复: 1
Jen Wells
更新时间 2021-06-17 00:36:39 UTC
浏览: 7377   回复: 1
System stuck on watering
Haris Eliades
更新时间 2021-06-17 05:07:11 UTC
浏览: 7303   回复: 2
Network error
Al Piscopo
更新时间 2021-06-17 10:27:03 UTC
浏览: 6743   回复: 1
Smart zone predictions?
Sid Smith
更新时间 2021-06-17 12:12:33 UTC
浏览: 7318   回复: 1
How to turn off Smart control
Riccardo Secco
更新时间 2021-06-17 19:47:41 UTC
浏览: 7098   回复: 1
aceking
更新时间 2021-06-18 12:41:57 UTC
浏览: 6926   回复: 2
Google home
Sasha Obradovic
更新时间 2021-06-18 13:56:27 UTC
浏览: 7627   回复: 2
Smart watering
Scott Schoenfeld
更新时间 2021-06-19 18:25:03 UTC
浏览: 7351   回复: 2
BOB COOPER
更新时间 2021-06-20 16:40:50 UTC
浏览: 11804   回复: 1
Programs that ignore sensors?
Jacques
更新时间 2021-06-20 19:10:17 UTC
浏览: 8722   回复: 1
Richtiger niederschlag
Gregor Schuller
更新时间 2021-06-21 09:41:39 UTC
Hallo,
Zurzeit ist nur 1 mm möglich
浏览: 7313   回复: 1
Ken Laberteaux
更新时间 2021-06-22 04:16:23 UTC
浏览: 8942   回复: 2
Still irigates on rain days
Anyhony Harwood
更新时间 2021-06-24 11:30:50 UTC
浏览: 8349   回复: 1
Reset whisper sensor
Yuriy Andamasov
更新时间 2021-06-24 18:06:20 UTC
Like hard reset
Not like that
浏览: 8824   回复: 1
Sensor not reading moisture
8
更新时间 2021-06-24 19:37:55 UTC
I have three whisper sensors,  all of them  but one is reporting moisture levels.  Temperature and sunlight are correct, but moisture is 0%.. I have reset the self learning, Did a hard reboot, and  Reattached the sensor to a different wireless network.  What else can be done?
浏览: 8339   回复: 1
