beta tester
更新时间 2021-06-06 07:50:32 UTC
浏览: 7794   回复: 1
Pause a location\device
Jon Storch
更新时间 2021-06-06 23:08:20 UTC
-Jon Storch
浏览: 7472   回复: 1
Whisperer in the UK
Lyndon Whyatt
更新时间 2021-06-07 10:59:12 UTC
浏览: 9532   回复: 1
Gianluca De Virgilio
更新时间 2021-06-07 16:13:28 UTC
Good afternoon,
Gianluca
浏览: 8886   回复: 1
Low pressure on pixie
Martin Le Ménach
更新时间 2021-06-08 07:20:16 UTC
浏览: 8557   回复: 1
Network Error With Code: 3404
Ian Meyer
更新时间 2021-06-08 16:16:25 UTC
浏览: 7553   回复: 1
Spark not watering lawn
更新时间 2021-06-09 14:26:58 UTC
浏览: 7833   回复: 1
Choice of irrigation hardware
Lyndon Whyatt
更新时间 2021-06-09 21:01:28 UTC
Hi I have ordered a Netro spark controller and three sensors. My next step is choosing 12VAC solenoids, a drip irrigation system for beds and pots and a misting system for my propagation bench.
I am new to this and would appreciate a pointer to recommended setups and suppliers.
Do I locate valves near to the Spark and run underground hoses to my beds or am I better off running cables to valves next to the beds? What are the pros and cons?
浏览: 9417   回复: 1
更新时间 2021-06-10 05:30:31 UTC
浏览: 7473   回复: 1
Skipping watering
Sid Smith
更新时间 2021-06-10 21:04:56 UTC
浏览: 8593   回复: 0
Skipping watering
Sid Smith
更新时间 2021-06-10 21:05:17 UTC
浏览: 8803   回复: 1
Marigolds
更新时间 2021-06-10 23:51:43 UTC
What is eating my marigolds
浏览: 7356   回复: 0
Whisperer won't blink white during setup
Kevin Westling
更新时间 2021-06-12 03:01:46 UTC
Prior to installing a whisperer to my system, I set it up outside in direct sunlight for 5 days. When I try to add it to my Sprite, the light only blinks red once. I've tried multiple times to press the power button 6 times and it's still just flashing red just once. What am I doing wrong?
浏览: 9388   回复: 1
Change sensor zone?
Jeff W
更新时间 2021-06-12 14:23:07 UTC
浏览: 7111   回复: 1
Confused....to sensor or not to sensor?
Kevin Westling
更新时间 2021-06-12 14:37:12 UTC
I'm only using a sprinkler system to water St. Augustine grass on a .2 acres in South Florida. The entire area is flat and has the same soil make-up (loam). Direct sunlight shines mostly all day on every area other than a small 10'x40' strip on the west side of the house that is shaded part of the day. I have no trees and no plants. I have a Sprite controller and 1 whisperer sensor which is connected to the 3 zones that get the most sunlight. The learned % is at 55%
I don't see any benefit in using the whisperer. Thoughts?
浏览: 8868   回复: 1
Text overlap in App
Kevin Westling
更新时间 2021-06-12 14:46:02 UTC
浏览: 7332   回复: 1
Installation of sprite
Mark Killeen
更新时间 2021-06-12 21:53:35 UTC
I have all connected and seems fine but when testing turning on each station I get a "pending" but no sction!
Each zone then said"loading"  for 5 minutes each then nothing. Please offer any help!
浏览: 9339   回复: 2
Connection issue
bridgethr
更新时间 2021-06-13 18:17:52 UTC
浏览: 7416   回复: 2
Whisperer Bad Readings
Billy Wood
更新时间 2021-06-13 19:42:18 UTC
浏览: 8700   回复: 1
Rebekah H
更新时间 2021-06-13 19:48:23 UTC
Any ideas?
Rebekah
浏览: 7579   回复: 2
