Not skipping raining days
Felipe VNunes
更新时间 2026-04-17 23:00:44 UTC
Hi guys,
My Netro system is not skipping watering on rainy days. As shown below, it still watered even though it is configured to skip the previous day, the rainy day itself, and the day after. Any recommendations?
浏览: 3253   回复: 1
enable switch
Andrew McNaughtan
更新时间 2026-04-19 22:32:06 UTC
I switched the enable switch in the Netro app to disable and now I can't get it to turn back on. The app says "next run not scheduled". When I close the app and reopen it, the switch has moved back to the disabled position. Nothing works, I can't even manually water. The controller has a green light showing and I have tried powering the controller off and back on and it reconnects without an issue but the app will not work.
浏览: 3327   回复: 1
Different weather and does not skip rainy days
Leonardo A
更新时间 2026-04-20 06:25:01 UTC
Good morning, if anyone can help me, I have two Netro control units installed 1 km from each other and they give me two different forecasts, both having the same weather portal, one irrigates it even with rainy days, while the other gives me the programming in 20 days.....
浏览: 3727   回复: 1
When Zone 11 is programmed to run but zone 4 runs instead.
Mike
更新时间 2026-04-21 18:10:56 UTC
Zone 4 correctly runs when zone 4 is activated
浏览: 3267   回复: 1
Feature Request / Setup Assistance: Apply Rain Skip to User Programs without Smart Scheduling
Alessandro Zannini
更新时间 2026-05-01 16:47:43 UTC
Hello Netro Support Team,
I am a user of the Netro system and I need assistance with my zone configuration.
Currently, I have a specific zone (named "Goccia") set up with a User Program (fixed days and fixed minutes). I do not want the Netro AI to change my watering duration or frequency.
However, I want the system to automatically skip my fixed program if it rains or if rain is predicted.
In my app settings for this zone, I see that "Smart Zone" is currently Disabled. My questions are:
1. If I enable "Smart Zone", will it overwrite my manual minutes and days, or will it only apply the "Rain Skip" feature to my existing User Program?
2. How can I ensure that the system follows my fixed schedule strictly, but still uses weather data to skip cycles during rain?
I want my manual program to be "Weather-aware" without becoming "AI-controlled".
Thank you for your help.
Best regards,
浏览: 2728   回复: 1
Notifications sur Android
Cyrille ROBINET
更新时间 2026-05-03 16:14:14 UTC
Bonjour,
J'aimerais avoir de l'aide.
Merci
浏览: 2749   回复: 1
programs - reordering
Lee Hill
更新时间 2026-05-08 06:40:14 UTC
浏览: 2688   回复: 1
programs - status sign
Lee Hill
更新时间 2026-05-08 06:45:32 UTC
Developers, can you add some indication to list of programs to see which is enabled, which is not?
Instead of going into each and scroll to the very bottom to check 'enabled'.
I think of either being grayed out or adding a sign, whatever simplest may work.
thank you
浏览: 2634   回复: 1
New feature request
更新时间 2026-05-10 19:34:04 UTC
浏览: 2665   回复: 1
My password
Cliff Howatd
更新时间 2026-05-11 14:08:56 UTC
My password keeps dropping, and I have to re-enter the password every time I want to use my phone to access programs.
浏览: 2663   回复: 1
Sensores fallan
Juan Pascual
更新时间 2026-05-12 13:01:26 UTC
Todos los sensores que he adquirido al cabo de dos años dejan de cargarse por el panel solar y son inservibles
Conectados por usb a una fuente de alimentación son capaz de emparejarse pero al desconectarse dejan de funcionar
Enchufados a la corriente la luz única un bucle de rojo de menos a más parpadeo amarillo y parpadeo verde. Los puedo dejar cargando por usb 12 horas pero al desconectarlo se mueren
Alguna solución ?
浏览: 2640   回复: 1
Zones not running
Richard Snyder
更新时间 2026-05-14 13:48:46 UTC
All zones are programmed to run but only zone 1 runs.
浏览: 2594   回复: 2
Why would it show rain on the Home Screen when there is none in the forecast
Michael Harrington
更新时间 2026-05-16 01:39:35 UTC
浏览: 2585   回复: 1
Longer watering per zone
Ruud
更新时间 2026-05-16 21:17:27 UTC
I have a Netro Sprite (6 zones).
I would like to water one time a week, 4 hours per zone in one run. I am not able to make programmes and single runs longer than 60 minutes.
Am I doing something wrong, or is this not supported?
Thanks for helping me out.
浏览: 2587   回复: 2
Riego manual
Javier Galván Romo
更新时间 2026-05-18 11:15:08 UTC
¿Como puedo hacer un riego manual zona a zona para comprobar lis goteros obstruidos?
浏览: 2884   回复: 1
Changing WiFi Network post original installation
deleted_20260518221841_george
更新时间 2026-05-18 14:03:27 UTC
Hi- been using your sprinkler controller for several years and have recently added a new WiFi network.
I'm following the instructions how to switch the Netro controller to a new WiFi network. After resetting the controller, it change my iphone WiFi network over to Netro-XXX (which tells me I have no internet access).
When I return to the Netro app and click 'Next', it just keeps instructing me to connect to Netro-XXX first.
The Netro controller continues to blink despite unplugging it so stuck in limbo now.
浏览: 2559   回复: 2
Change Wi-Fi connection
Ruth Wengert
更新时间 2026-05-20 03:18:14 UTC
I have changed the name of my Wi-Fi. I need to change my Wi-Fi connection to its new name
浏览: 2499   回复: 1
Ruth Wengert
更新时间 2026-05-20 03:19:27 UTC
I have changed the name of my Wi-Fi. I need to change my Wi-Fi connection to its new name I have a new Wi-Fi in your hub will not work because it can’t download a new Wi-Fi for some damn reason
浏览: 2546   回复: 0
Ruth Wengert
更新时间 2026-05-20 03:19:34 UTC
浏览: 2697   回复: 2
Greenhouse zone
Ivan G
更新时间 2026-05-20 08:59:47 UTC
浏览: 3987   回复: 1
