Will
更新时间 2026-01-27 03:13:26 UTC
浏览: 3300   回复: 1
cpline
更新时间 2026-02-02 17:04:38 UTC
浏览: 3321   回复: 1
Notification
Alexis Demosthenous
更新时间 2026-02-05 19:28:19 UTC
浏览: 3402   回复: 1
Will
更新时间 2026-03-17 21:54:57 UTC
浏览: 4047   回复: 3
Sensor to zone
Mark Zeck
更新时间 2026-02-05 23:17:03 UTC
How do I connect my sensors to zones? I have the latest.
浏览: 3404   回复: 1
Feature Request
John Sirois
更新时间 2026-02-10 05:56:14 UTC
John
浏览: 3218   回复: 1
Supported Hardware
Colin Brierley
更新时间 2026-02-12 06:13:48 UTC
浏览: 3694   回复: 1
Support email- No reply
更新时间 2026-02-21 16:06:19 UTC
浏览: 3453   回复: 2
RKR Home
更新时间 2026-03-03 03:32:35 UTC
浏览: 3298   回复: 1
New whisperer
更新时间 2026-03-03 08:20:29 UTC
Bought a new whisperer as an old one is no longer working.
REMARK : WHILE I LIVE IN A TEMPERATE AREA NONE OF MY WHISPERERS LASTS MORE THAN 26 MONTHS WHICH IS SURPRISING AS IT IS NOT SUPPOSED TO BE A CONSUMABLE.
Clicked as required first blinking blue light then blinking white light.
Went to sensors and see the dead old one, the working one but do not see the newly bought one.
Do not see either a + sign to add a new one.
What should I do ?
浏览: 3268   回复: 1
Monkeyzu
更新时间 2026-03-12 08:20:45 UTC
浏览: 3225   回复: 1
Seeding mode
John Sirois
更新时间 2026-03-15 04:23:37 UTC
浏览: 3261   回复: 1
Adding a 2nd system
Jayden Lockley
更新时间 2026-03-21 07:03:33 UTC
I currently have a Netro Sprite system set up on a bore, I'm only using 9 stations currently but I can't easily add any more stations/wiring to this system.
I can easily access the wiring where I would like to add more stations, am I able to pick up the earth and pump start wires, and add a 2nd sprite or spark controller there?
Or has anyone got any ideas of how I can add more stations without running more wiring back to the master controller?
浏览: 3294   回复: 1
Drip
Tim P
更新时间 2026-03-22 18:03:43 UTC
All the zones work except I do not have any water coming out of the drip heads
浏览: 2949   回复: 1
Drip
Tim P
更新时间 2026-03-22 18:03:51 UTC
浏览: 2970   回复: 1
Drip
Tim P
更新时间 2026-03-22 18:23:10 UTC
浏览: 2951   回复: 1
Pixie se desconecta
Lino
更新时间 2026-03-22 19:30:16 UTC
Por qué se desconecta después de unos minutos mi unidad Pixie si tiene batería?
浏览: 3058   回复: 1
Combine 2 zones
Alexis Demosthenous
更新时间 2026-04-07 03:33:14 UTC
Hello everyone,
For my lawn i have 2 watering zones, is there a way to "force" schedule to combine those 2 zones to always follow each other? I dont want to water half my lawn on Monday and the other half on Thursday.
浏览: 2993   回复: 2
Any way for user to open and replace battery in Whisperer 2?
更新时间 2026-04-09 02:24:02 UTC
Any way for end user to open and replace battery on a whisperer 2?  It is out of warranty.
浏览: 3002   回复: 1
Multiple locations
paul.robinson@bigbend.net
更新时间 2026-04-12 21:06:55 UTC
浏览: 2948   回复: 1
