Zone flexibility
Mike R
Actualizado 2025-10-29 01:20:50 UTC
I have a hill that was terraced and replanted. I was told to run the circuit twice a day for 15 minutes for a month. Drip lines. Seems like my system doesn’t have that flexibility. Am i correct?
Ver: 4322   Respuesta: 1
API broken?
Tortfeaser
Actualizado 2025-11-21 04:58:13 UTC
Hi, I can get my Netro controller info using:
curl -v https://api.netrohome.com/npa/v2/info.json?key=MYAPIKEY
(where MYAPIKEY is a key from the user account page)
but when I try to update soil moisture data with:
curl -X POST -H "Accept: application/json" -H 'Content-Type:application/json' -d '{"key":"MYAPIKEY","moisture":100}' "https://api.netrohome.com/npa/v2/set_moisture.json"
I get an error about an invalid key:
{"status":"ERROR","meta":{"time":"2025-11-21T04:54:56","tid":"1763700896_KpmY","version":"2.0","token_limit":0,"token_remaining":0,"last_active":"2025-11-21T04:54:56","token_reset":"2025-11-22T00:00:00"},"errors":[{"code":1,"message":"Invalid key: ","params":{}}]}
What's going on?
Ver: 16303   Respuesta: 1
Cannot add pixie z1
John R
Actualizado 2025-12-09 02:23:46 UTC
I cannot add my pixie z1 to the app because pixie z1 is not shown as an option. I have the hub connected.
Ver: 4086   Respuesta: 1
Watering on wrong day
keller3987
Actualizado 2025-12-09 15:39:44 UTC
I have programmed my Netro to skip Tuesday’s but the controller waters anyway. How do I stop this?
Ver: 3921   Respuesta: 1
The average temperature for a day is insufficient to calculate correct watering.
Richard
Actualizado 2025-12-17 07:17:57 UTC
When I have Whisperers, the system appears to calculate the average over the day about 4 degrees higher than for zones without Whisperers.
It seems that, even though the weather data is available throughout the day, that zones without sensors only use the forecast high and low.
This is insufficient to correctly adjust for the amount of watering required.
For example, today is 7 degrees C up to 36.
Whisperer zones average the temp at 26C while non-Whisperer zone calculate the average at 22C.
On these extremely hot days, the non-whisperer zones are under-watering much more than the Whisperer zones.
Also note that even the zones with Whisperers always under-water and needs custom programs or manual intervention.
This finally explains to me why zones are always under-watered.
Can the system please use multiple day readings for non-Whisperer zones and PLEASE provide more watering?
Ver: 3943   Respuesta: 2
Eric Jonsson
Actualizado 2026-01-08 12:02:58 UTC
Ver: 3915   Respuesta: 1
Shane V
Actualizado 2026-01-19 04:54:45 UTC
Ver: 3758   Respuesta: 1
Old whisperer
Actualizado 2026-01-20 10:38:33 UTC
Seems a communication problem
Ver: 3655   Respuesta: 1
Tuan Phan
Actualizado 2026-01-25 18:28:34 UTC
Ver: 3523   Respuesta: 1
Will
Actualizado 2026-01-27 03:13:26 UTC
Ver: 3708   Respuesta: 1
cpline
Actualizado 2026-02-02 17:04:38 UTC
Ver: 3723   Respuesta: 1
Notification
Alexis Demosthenous
Actualizado 2026-02-05 19:28:19 UTC
Ver: 3765   Respuesta: 1
Will
Actualizado 2026-03-17 21:54:57 UTC
Ver: 4422   Respuesta: 3
Sensor to zone
Mark Zeck
Actualizado 2026-02-05 23:17:03 UTC
How do I connect my sensors to zones? I have the latest.
Ver: 3797   Respuesta: 1
Feature Request
John Sirois
Actualizado 2026-02-10 05:56:14 UTC
John
Ver: 3575   Respuesta: 1
Supported Hardware
Colin Brierley
Actualizado 2026-02-12 06:13:48 UTC
Ver: 4050   Respuesta: 1
Support email- No reply
Actualizado 2026-02-21 16:06:19 UTC
Ver: 3854   Respuesta: 2
RKR Home
Actualizado 2026-03-03 03:32:35 UTC
Ver: 3688   Respuesta: 1
programs - reordering
Lee Hill
Actualizado 2026-05-08 06:40:14 UTC
Ver: 2657   Respuesta: 1
Notifications sur Android
Cyrille ROBINET
Actualizado 2026-05-03 16:14:14 UTC
Bonjour,
J'aimerais avoir de l'aide.
Merci
Ver: 2714   Respuesta: 1
