Arghhh, so horrible
Jake Tanner
Actualizado 2023-09-09 16:24:29 UTC
Ver: 8289   Respuesta: 1
Whisperer stake cracked
Actualizado 2023-09-09 20:22:46 UTC
Ver: 8858   Respuesta: 1
Soil moisture adjustment
Actualizado 2023-09-12 01:34:23 UTC
Ver: 8896   Respuesta: 1
Scheduling Issue
Steve Loesch
Actualizado 2023-09-12 13:59:31 UTC
First.
Second.
Ver: 8416   Respuesta: 1
Change Wifi problem
Luciani Daniele
Actualizado 2023-09-12 15:54:28 UTC
Ver: 8202   Respuesta: 1
smart zone advanced range
Leandro
Actualizado 2023-09-12 17:37:36 UTC
Thanks for the reply
Leandro
Ver: 8255   Respuesta: 1
David Solis
Actualizado 2023-09-14 21:05:39 UTC
Thank you in advance
David
Ver: 8746   Respuesta: 2
My device is offline
carlos davalos melgar
Actualizado 2023-09-17 18:50:32 UTC
i
How can I reconnect to Wi-Fi
the controller light is green
Please i need help
Ver: 8793   Respuesta: 1
Copy setting to new spark device
John Wright
Actualizado 2023-09-17 19:57:29 UTC
My original netro spark died and I have received a new one.  Is there a way to copy the zone settings from the old to the new
Ver: 10908   Respuesta: 1
Stephen CC
Actualizado 2023-09-19 08:44:03 UTC
Ver: 8304   Respuesta: 1
Unrequested watering cycle
Claudio Polacco
Actualizado 2023-09-23 07:00:27 UTC
Hello everybody, maybe someone can help.
This morning I found the irrigation system on, watering the garden, with no schedule active. More, the master enable/disable switch on the app homepage was set to off.
I'm using manual zone scheduling, not smart watering.
The controller is a Netro Sprite 6 zones, Wifi was on and fully functional.
Any ideas? Thanks.
Claudio
Ver: 8504   Respuesta: 1
Horario
Conchi Herrero
Actualizado 2023-09-27 13:00:48 UTC
Gracias.
Ver: 8269   Respuesta: 1
Schedule
Jim Lacy
Actualizado 2023-09-28 02:00:48 UTC
Ver: 8637   Respuesta: 1
kamiller42
Actualizado 2023-09-29 15:44:58 UTC
Ver: 8148   Respuesta: 1
Whisperer 2 "serial already in used" issue
pridebowl33
Actualizado 2023-09-29 16:07:36 UTC
I have been trying to add back one of my Whisperer 2 sensor and got a message saying that the serial has been already in used. Not sure what to do at this point. I was wondering if someone had encountered the same issue and if there is a solution to fix it.
Kevin
Ver: 8437   Respuesta: 1
Phil Middleton
Actualizado 2023-09-30 12:48:53 UTC
Kind regards
Phil
Ver: 8789   Respuesta: 1
2 zonas funcionando a la vez?
Juan Carlos
Actualizado 2023-09-30 18:53:13 UTC
Ver: 8648   Respuesta: 1
Zone Failure
Ben Pittarelli
Actualizado 2023-10-03 12:31:07 UTC
I have the Sprite 12 controller with zone 3 failing to work after 10 months.  Traced error to low voltage on controller. Anyone else having zone failures caused by controller?
Moved wire to unused zone 12 and sprinklers engage as they should.
Ver: 8482   Respuesta: 1
Linking Google Home to Netro
cadry1969
Actualizado 2023-10-07 03:21:23 UTC
Ver: 8386   Respuesta: 2
Yellow exclamation mark
MyGowdy
Actualizado 2023-10-07 23:05:24 UTC
Ver: 8404   Respuesta: 1
