Franck FONTANEL
Actualizado 2025-07-18 19:49:49 UTC
I don’t know why ?
Ver: 7257   Respuesta: 1
Pause
Tamgar chan
Actualizado 2025-07-19 10:59:15 UTC
Ver: 7561   Respuesta: 1
Whisperer low battery alert
Jesus Sanguinetti
Actualizado 2025-07-19 15:24:34 UTC
Ver: 7623   Respuesta: 1
Stefano
Actualizado 2025-07-21 21:17:23 UTC
Hi everyone,
I’ve already tried:
Thanks in advance!
– Stefano
Ver: 7731   Respuesta: 1
Change zone order
Matt Ward
Actualizado 2025-07-22 00:43:18 UTC
Ver: 7910   Respuesta: 1
Andrew Woods
Actualizado 2025-07-22 19:30:55 UTC
Ver: 5129   Respuesta: 1
Interoperability with Alexa, Homey, any other smart home platform?
arnaud@brucy.org
Actualizado 2025-08-22 19:03:11 UTC
Is there any interoperability/integration existing or planned with home automation/smart home platforms?
Integration with Homey Pro would be great, being able to fetch the watering status for each zone, start a manual watering, or send some external triggers (humidity, rain water tank level, etc.)
Thank you !
Arnaud
Ver: 6941   Respuesta: 2
Password
Ignacio Sánchez
Actualizado 2025-09-26 11:38:52 UTC
Ver: 5086   Respuesta: 1
Whisperer installation
Davide Chelo
Actualizado 2025-09-26 11:38:17 UTC
Hi, I just bought the whisperer 2 and would like to have it as only sensor for the entire garden, however is allowed to have maximum 3 zones for sensor. Is there a way to link all the zones to it? I have 7 zones.
Ver: 4971   Respuesta: 1
I want to change wifi network my Netro controller is connected too.
loro
Actualizado 2025-09-23 21:27:44 UTC
How do I change the wifi network my Netro controller is connected too? I cannot proceed beyond step 2 from the instructions on the app. I get the message "Please connect to Wi-fi network "Netro_IRC_xxx."  However, the app shows that I am already connected!!
Ver: 5492   Respuesta: 1
Info function
Giuseppe
Actualizado 2025-09-20 09:48:50 UTC
Ver: 5601   Respuesta: 1
Program change Day
Tiziano Pacella
Actualizado 2025-09-17 19:04:30 UTC
Someone can help me?I need change the day for one program exists...what is the procedure? Thak you
Ver: 5523   Respuesta: 1
Rainbird esp me series
Magnus Swenson
Actualizado 2025-09-15 14:38:33 UTC
Can I use the Netro Spark 16 if I use the Rainbird ESP Me? I have 15 active zones.
Ver: 5809   Respuesta: 1
Time
Silvano Scotto
Actualizado 2025-09-10 23:18:59 UTC
Ver: 6336   Respuesta: 1
Centralina non funziona
gsciurba
Actualizado 2025-09-09 19:23:32 UTC
Buongiorno,
  • la tensione in uscita è sempre di circa 11 V AC su tutte le uscite;
  • la centralina è stata utilizzata pochissimo, solo con le zone master e 1–2;
  • non sono presenti segni visibili di bruciatura o danni hardware.
Grazie per l’attenzione.
Cordiali saluti,
Giuseppe Sciurba
Ver: 6291   Respuesta: 1
Netro spark no work
Fernando Bravo Calatayud
Actualizado 2025-09-04 08:25:22 UTC
I've had a Netro Spark 8 working without any problems since last year, but a few days ago it disconnected from the Wi-Fi and stopped working. I tried the reset button as indicated in the instructions, but there's no way to reconnect it. What else can I do? Thank you very much
Ver: 6743   Respuesta: 1
Francesco Gritti
Actualizado 2025-08-29 16:39:06 UTC
Ver: 7012   Respuesta: 1
Actualizado 2025-08-24 22:55:28 UTC
Ver: 7252   Respuesta: 1
Non riesco a connettere metro spring con metro wisperer
Fabio Doc
Actualizado 2025-08-23 07:43:08 UTC
Ver: 7247   Respuesta: 1
Interpretation of soil moisture readings by Whisperer
Missy Bartell
Actualizado 2025-07-26 12:13:30 UTC
I have two Whisperers that I move around to various parts of my graden to get comparative readings of sunlight and soil moisture.  I really do not know how to interpret the moisture readings which generally range from 50% to 98% but can be as low as 30%.  Soil type varies from a clayey loam to heavy clay.   How do I know when watering is required?  Does the meter measure the capillary water?  The adhered water?  The percentage of voids filled with water?  How does Netro calculate the percentage of water and what do the readings mean?
Ver: 5460   Respuesta: 1
