Actualizado 2023-07-24 00:54:03 UTC
Ver: 8594   Respuesta: 1
misterhoff
Actualizado 2023-07-25 03:11:25 UTC
Ver: 7775   Respuesta: 0
Feature request update
Actualizado 2023-07-25 06:11:19 UTC
Ver: 8397   Respuesta: 1
Netro - Stopped Working and won’t power up
John Loethen
Actualizado 2023-07-25 14:04:38 UTC
Been a Netro customer for a while and pretty handy. I have three different Netro controllers and my oldest one just stopped working and won’t power up… I have verified the power at the outlet and have changed out the power supply with another 24v power supply that I know works. Still the controller will not power up.
Let me know if anyone else has suggestions.
John in Lincoln, NE
Ver: 7983   Respuesta: 1
Netro Sprite 6 valve won’t stop
Alberto Casu
Actualizado 2023-07-29 19:25:45 UTC
I just replaced my sprinkler controller with a new Netro Sprite 6.
Using both a programmed or a manual start, all valves don’t stop unless I remove power to the Sprite.
During a program, where I planned the zones to run sequentially, the zones activate one after the other without stopping and causing the zones to loose pressure and be unable to complete.
On the FAQ, it says to remove power to stop the zone, which actually stop all the watering, but this it totally unusable to me.
I am using the European version with the provided power supplier. I am based in Italy.
Can you please help?
Ver: 8555   Respuesta: 2
Netro phone app won't open
Christopher Scarborough
Actualizado 2023-07-30 23:32:37 UTC
Ver: 7894   Respuesta: 1
Tim Quach
Actualizado 2023-08-01 08:02:49 UTC
Ver: 7876   Respuesta: 1
Atif Siddiqui
Actualizado 2023-08-02 04:51:58 UTC
Ver: 7875   Respuesta: 1
Using Bootlace ferrules.
Bob Howard
Actualizado 2023-08-03 06:36:09 UTC
I'd like to use bootlace ferrules for all the wiring to the sprite as shown in your installation video (power connection). I'm using 0.5mm² x 7 core cable and 0.5mm² bootlaces and the unit won't grip them. I've tried other sizes with the same result. What size ferrule is required?
Ver: 10504   Respuesta: 1
Date format
Bob Howard
Actualizado 2023-08-03 23:27:42 UTC
Ver: 8537   Respuesta: 1
David H
Actualizado 2023-08-04 17:15:09 UTC
Ver: 8076   Respuesta: 1
App show’s pending message
Greg Jones
Actualizado 2023-08-07 18:46:13 UTC
Ver: 8183   Respuesta: 1
Drew M
Actualizado 2023-08-08 17:48:40 UTC
Ver: 7723   Respuesta: 1
We had 4 inches of rain
Actualizado 2023-08-09 03:08:18 UTC
Ver: 8412   Respuesta: 2
Cambio wifi
jmgrau
Actualizado 2023-08-09 15:10:03 UTC
Espero su ayuda.
Ver: 7740   Respuesta: 1
App is not installing
Martin Trevino
Actualizado 2023-08-09 16:40:50 UTC
Ver: 7877   Respuesta: 1
Louise Brinkman
Actualizado 2023-08-10 05:52:23 UTC
Ver: 8391   Respuesta: 1
Spark and Sensors
C He
Actualizado 2023-08-10 06:45:57 UTC
Hi all,
Thanks for support!
Ver: 8213   Respuesta: 1
Calendar View
Actualizado 2023-08-10 11:23:26 UTC
Netro Support Team,
Houston, Texas
Ver: 8275   Respuesta: 1
technic support
Isabel Santillan
Actualizado 2023-08-11 07:07:33 UTC
Ver: 7646   Respuesta: 1
