How stop 1 day
Leonardo Antonucci
更新時間 2020-10-11 18:33:55 UTC
瀏覽: 6865   回覆: 1
"Next in" shows "--"
Luis Aguilar
更新時間 2020-10-14 18:45:01 UTC
瀏覽: 6937   回覆: 1
Netro unit
Bhumit Joshi
更新時間 2020-10-16 18:15:51 UTC
I just got my system winterized today. Netro box is still on. Do i just unplug it for the winter?
瀏覽: 8345   回覆: 1
Problem With application
Alex Guerrero
更新時間 2020-10-17 08:21:08 UTC
瀏覽: 6919   回覆: 1
Manually entering rainfall
Curt Lizzi
更新時間 2020-10-17 13:16:09 UTC
瀏覽: 7351   回覆: 1
David Farries
更新時間 2020-10-24 20:24:40 UTC
瀏覽: 7276   回覆: 1
Email address length
Alberto Castro Hinojosa
更新時間 2020-10-24 21:37:57 UTC
Could you review please?
瀏覽: 8450   回覆: 1
Stefan Pena
更新時間 2020-10-25 10:41:41 UTC
Hey guys!
瀏覽: 6851   回覆: 1
New user
Haris Eliades
更新時間 2020-10-28 20:35:38 UTC
Hello!
Zone 4, 2 minutes
Zone 5, 2 minutes
Zone 1, 4 minutes
Zone 2, 4 minutes
Zone 3, 4 minutes
Zone 4, 4 minutes
Zone 5, 2 minutes
瀏覽: 7037   回覆: 1
How do I turn off for Winter?
Paul A
更新時間 2020-10-30 20:59:47 UTC
瀏覽: 6928   回覆: 2
Add zones manually in queue
Haris Eliades
更新時間 2020-11-03 04:04:49 UTC
瀏覽: 7230   回覆: 1
Didn’t water. Exclamation point inside of triangle
更新時間 2020-11-03 11:05:39 UTC
Controller didn’t turn on sprinklers at 0400hrs today.  Instead schedule shows yellow triangle with exclamation symbol, but gives no breakdown on why system didn’t turn on water.  If controller shows exclamation, it would be nice if it showed an actual description of problem/event.
瀏覽: 9425   回覆: 1
dinzdale
更新時間 2020-11-03 16:00:28 UTC
瀏覽: 6964   回覆: 1
Curt Lizzi
更新時間 2020-11-03 18:41:08 UTC
Am I doing something wrong?
Curt
瀏覽: 7477   回覆: 1
Offline buy watered
Haris Eliades
更新時間 2020-11-09 06:22:11 UTC
瀏覽: 7084   回覆: 1
Stan Balafas
更新時間 2020-11-16 17:52:28 UTC
Thank ypu
瀏覽: 6893   回覆: 1
Jens Wymeersch
更新時間 2020-11-17 13:25:17 UTC
Dear,
Thank you so much,
Jens
瀏覽: 8046   回覆: 2
App stuck on Idle
Pam Manwaring
更新時間 2020-11-18 02:21:16 UTC
瀏覽: 6812   回覆: 1
Sensor and zone of control
Andrea Pieri
更新時間 2020-11-20 19:49:29 UTC
Dear support right now i am installing my new sensor connected with netro controller ( this is the first sensor) . I have 5 zone active but sensor is able to control just 3 zone is possibile to extend the sensor control  to a global of 5 zone for one sensor ? Thanks for your help .
瀏覽: 8659   回覆: 1
Whisperer Battery
growerken
更新時間 2020-11-23 16:44:00 UTC
I have one whisperer,used in indoor garden.it looks like the solar is not enough for the charging.
Any idea I can fix it?
瀏覽: 9057   回覆: 1
