Arghhh, so horrible
Jake Tanner
更新時間 2023-09-09 16:24:29 UTC
瀏覽: 8284   回覆: 1
Whisperer stake cracked
更新時間 2023-09-09 20:22:46 UTC
瀏覽: 8853   回覆: 1
Soil moisture adjustment
更新時間 2023-09-12 01:34:23 UTC
瀏覽: 8891   回覆: 1
Scheduling Issue
Steve Loesch
更新時間 2023-09-12 13:59:31 UTC
First.
Second.
瀏覽: 8406   回覆: 1
Change Wifi problem
Luciani Daniele
更新時間 2023-09-12 15:54:28 UTC
瀏覽: 8198   回覆: 1
smart zone advanced range
Leandro
更新時間 2023-09-12 17:37:36 UTC
Thanks for the reply
Leandro
瀏覽: 8250   回覆: 1
David Solis
更新時間 2023-09-14 21:05:39 UTC
Thank you in advance
David
瀏覽: 8734   回覆: 2
My device is offline
carlos davalos melgar
更新時間 2023-09-17 18:50:32 UTC
i
How can I reconnect to Wi-Fi
the controller light is green
Please i need help
瀏覽: 8787   回覆: 1
Copy setting to new spark device
John Wright
更新時間 2023-09-17 19:57:29 UTC
My original netro spark died and I have received a new one.  Is there a way to copy the zone settings from the old to the new
瀏覽: 10906   回覆: 1
Stephen CC
更新時間 2023-09-19 08:44:03 UTC
瀏覽: 8294   回覆: 1
Unrequested watering cycle
Claudio Polacco
更新時間 2023-09-23 07:00:27 UTC
Hello everybody, maybe someone can help.
This morning I found the irrigation system on, watering the garden, with no schedule active. More, the master enable/disable switch on the app homepage was set to off.
I'm using manual zone scheduling, not smart watering.
The controller is a Netro Sprite 6 zones, Wifi was on and fully functional.
Any ideas? Thanks.
Claudio
瀏覽: 8499   回覆: 1
Horario
Conchi Herrero
更新時間 2023-09-27 13:00:48 UTC
Gracias.
瀏覽: 8258   回覆: 1
Schedule
Jim Lacy
更新時間 2023-09-28 02:00:48 UTC
瀏覽: 8631   回覆: 1
kamiller42
更新時間 2023-09-29 15:44:58 UTC
瀏覽: 8142   回覆: 1
Whisperer 2 "serial already in used" issue
pridebowl33
更新時間 2023-09-29 16:07:36 UTC
I have been trying to add back one of my Whisperer 2 sensor and got a message saying that the serial has been already in used. Not sure what to do at this point. I was wondering if someone had encountered the same issue and if there is a solution to fix it.
Kevin
瀏覽: 8429   回覆: 1
Phil Middleton
更新時間 2023-09-30 12:48:53 UTC
Kind regards
Phil
瀏覽: 8786   回覆: 1
2 zonas funcionando a la vez?
Juan Carlos
更新時間 2023-09-30 18:53:13 UTC
瀏覽: 8640   回覆: 1
Zone Failure
Ben Pittarelli
更新時間 2023-10-03 12:31:07 UTC
I have the Sprite 12 controller with zone 3 failing to work after 10 months.  Traced error to low voltage on controller. Anyone else having zone failures caused by controller?
Moved wire to unused zone 12 and sprinklers engage as they should.
瀏覽: 8477   回覆: 1
Linking Google Home to Netro
cadry1969
更新時間 2023-10-07 03:21:23 UTC
瀏覽: 8380   回覆: 2
Yellow exclamation mark
MyGowdy
更新時間 2023-10-07 23:05:24 UTC
瀏覽: 8398   回覆: 1
